When I have two monitors attached to my x1800xt during bootup, X, Unity or the graphics driver crashes during the last stage (loading UI when the monitor setup changes from mirror to extended, tty is still working, killing X does not solve the problem, after some tries both monitor just go to sleep).
However, when I plug in the second monitor after bootup, it works fine. (standard ubuntu 12.04 kernel). After updating to the newest linux 3.4rc2 Kernel this problem is still present, however suspend and resume works fine with dualhead (didn't work with the old kernel) and the fan of the graphics card doesn't go wild anymore after resume. One of the monitors is attached directly over DVI-D the other is attached with an DVI-I to VGA adapter. Both of them are independently working fine. In the system settings they are both identified correctly with the correct resolution, however things like rotation is buggy and kind of crashes as well. (I have to change resolution AND rotation simultaniously in order to change the rotation otherwise the system crashes).
Is there some logfile I could post where these errors would be logged?
3d-Acceleration is working on both monitors when I plug in the second monitor after bootup.
lspci output:
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI R520 [Radeon X1800]
01:00.1 Display controller: Advanced Micro Devices [AMD] nee ATI R520 [Radeon X1800] (Secondary)
Subsystem: Advanced Micro Devices [AMD] nee ATI Device 0b12
Kernel driver in use: radeon
Kernel modules: radeon
Subsystem: Advanced Micro Devices [AMD] nee ATI Device 0b13
lshw output:
*-display:0
description: VGA compatible controller
product: R520 [Radeon X1800]
vendor: Hynix Semiconductor (Hyundai Electronics)
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:18 memory:d0000000-dfffffff memory:ceee0000-ceeeffff ioport:d000(size=256) memory:ceec0000-ceedffff
*-display:1 UNCLAIMED
description: Display controller
product: R520 [Radeon X1800] (Secondary)
physical id: 0.1
bus info: pci@0000:01:00.1
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress bus_master cap_list
configuration: latency=0
resources: memory:ceef0000-ceefffff
EDIT 1: By now I also compared the two Xorg.0.log files (coldplug vs hotplug) but I couldn't find suspicous behaviour. (only an error loading fglrx which was on both logs and is clear because I use the open source driver)
EDIT 2:
checked xrandr -d :0 everything seems fine to me
Screen 0: minimum 320 x 200, current 3200 x 1200, maximum 8192 x 8192
I also checked dmesg but I was unable to find anything suspicious.
DVI-0 connected 1920x1200+0+0 (normal left inverted right x axis y axis) 518mm x 324mm
1920x1200 60.0*+
1920x1080 60.0
1600x1200 60.0
1680x1050 60.0
1280x1024 60.0
1280x960 60.0
1024x768 60.0
800x600 60.3
640x480 60.0
720x400 70.1
S-video disconnected (normal left inverted right x axis y axis)
DVI-1 connected 1280x1024+1920+176 (normal left inverted right x axis y axis) 376mm x 301mm
1280x1024 60.0*+ 75.0
1152x864 75.0
1024x768 75.1 70.1 60.0
832x624 74.6
800x600 72.2 75.0 60.3 56.2
640x480 72.8 75.0 66.7 60.0
720x400 70.1
Could Someone name another logfile to look at, or should I file a bugreport?
