I have set up Ubuntu 21.04 Base image in Termux. When I run apt update, I get the following error. As I was not able to run apt update, I cannot install any packages.
root@localhost:~# apt update
Get:1 http://ports.ubuntu.com/ubuntu-ports hirsute InRelease [269 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports hirsute-updates InRelease [109 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports hirsute-backports InRelease [90.7 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports hirsute-security InRelease [101 kB]
Reading package lists... Done
E: Unable to determine file size for fd 7 - fstat (1: Operation not permitted)
E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute InRelease' provides only weak security information.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-updates InRelease' provides only weak security information.
E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-backports InRelease' provides only weak security information.
E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-security InRelease' provides only weak security information.
How to fix this? This error is absent in the 20.04.2 base image.
Here is the output for permissions of /tmp.
root@localhost:~# ls -ld /tmp
drwx------ 2 root root 3488 Jul  1 10:54 /tmp
Here is the sources.list (I have not modified it).
root@localhost:~# cat /etc/apt/sources.list
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ hirsute main restricted
# deb-src http://ports.ubuntu.com/ubuntu-ports/ hirsute main restricted
Major bug fix updates produced after the final release of the
distribution.
deb http://ports.ubuntu.com/ubuntu-ports/ hirsute-updates main restricted
deb-src http://ports.ubuntu.com/ubuntu-ports/ hirsute-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb http://ports.ubuntu.com/ubuntu-ports/ hirsute universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ hirsute universe
deb http://ports.ubuntu.com/ubuntu-ports/ hirsute-updates universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ hirsute-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb http://ports.ubuntu.com/ubuntu-ports/ hirsute multiverse
deb-src http://ports.ubuntu.com/ubuntu-ports/ hirsute multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ hirsute-updates multiverse
deb-src http://ports.ubuntu.com/ubuntu-ports/ hirsute-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb http://ports.ubuntu.com/ubuntu-ports/ hirsute-backports main restricted universe multiverse
deb-src http://ports.ubuntu.com/ubuntu-ports/ hirsute-backports main restricted universe multiverse
Uncomment the following two lines to add software from Canonical's
'partner' repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu hirsute partner
deb-src http://archive.canonical.com/ubuntu hirsute partner
deb http://ports.ubuntu.com/ubuntu-ports/ hirsute-security main restricted
deb-src http://ports.ubuntu.com/ubuntu-ports/ hirsute-security main restricted
deb http://ports.ubuntu.com/ubuntu-ports/ hirsute-security universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ hirsute-security universe
deb http://ports.ubuntu.com/ubuntu-ports/ hirsute-security multiverse
deb-src http://ports.ubuntu.com/ubuntu-ports/ hirsute-security multiverse
Correct permissions:
sudo chmod 777 -R /tmp
jasmines
  • 11,311
Please, locate the PID for apt update with:
ps ax | grep "apt"
When you know type:
ls -al /proc/PID/fd/
Where PID is the process number you obtained before.
What is the File Descriptor named 7?.
Update 2021-07-05:
May be it is normal.
According to Termux documentation https://wiki.termux.com/wiki/Package_Management :
Apt usage under root is restricted to prevent messing up ownership and SELinux labels on Android /data partition.
We strongly recommend to use a pkg utility instead of apt directly...
Downgrading is not supported. In order to reclaim disk space, we do not keep history of package versions.
Carles Mateo
  • 1,647
[As of 1st dec, 2021]
For me it was due to mounting to /tmp path with ubuntu 20.04. I had to change mount location to /usr/local/bin
Check here and here.
Koder101
  • 101
