I've just installed Ubuntu 12.04 (64-bit) on a brand new Dell Latitude e6420, and I'm having a few problems. This laptop has an Optimus (?) setup - i.e. integrated gfx and an Nvidia Quadro NVS 4200M.
First problem - I ran setup, etc, and discovered that I can only run unity2d - If I try and login with unity3d, it just defaults to 2d. This is with nvidia-current installed (302.07). Note also that I can't run
nvidia-settings("You do not appear to be using the NVIDIA X driver."), and there is no additional drivers found ("No proprietary drivers are in use on this system").I tried to troubleshoot this, and removed nvidia, leaving (I guess) just Nouveau drivers - In that case, unity3d did work, but I was stuck with the open source Nouveau drivers powering the integrated graphics.
So, obviously, I want to run unity3d, and be using the more powerful Nvidia graphics card.
I've tried a bit of tinkering around, but I'm not sure the best way to proceed, or perhaps more importantly, I'm not sure of what the best final solution might be. I've heard about bumblebee - but frankly, I would prefer to have the proprietary Nvidia drivers working properly.
Any help would be much appreciated!
