I've created a persistent linux installation using the often suggested method with the help of mkusb and installing the final system using the before-created partitioning scheme (see e.g. here: https://askubuntu.com/a/1107334/1043714 by @C.S.Cameron).
I now have doubt, that grub is installed correctly. When I edit /etc/default/grub (with e.g. some change in the timeout) and update-grub, I don't see any effect after reboot.
I suspect, it should put grub.cfg somewhere into /dev/sdx3 (which to my understanding is the acutal boot partition) instead of /dev/sdx5 (which is my actual / ) - but I'm not sure and additionally don't know, how EFI would come into play at this moment...
Thanks a lot in advance for guiding, pheidrias
Update GRUB on Full Install USB made using mkusb
The method you point to has one instance of GRUB for BIOS and another for UEFI.
Running sudo update-grub will update GRUB on / only.
To fully update GRUB, after doing sudo update-grub, copy /boot/grub/grub.cfg from sdx5 to /boot/grub/grub.cfg on sdx3.
I will update that answer.
That answer was something I wrote on my way to making How to Create a Full Install of Ubuntu 20.04 to USB Device Step by Step
C.S.Cameron
  • 20,530
  • 78
  • 125
