I have Windows 10 and Xubuntu linux installed on my surface go. I also use rEFInd boot manager. After some time (days, weeks, etc), my Xubuntu partition stops loading its GUI. I'll just boot into command line. I've actually reinstalled ubuntu on this machine to "fix" this issue but its basically just a bandaid solution. The issue just reappears overtime. My suspicion is that it has something to do windows and how my computer boots, however, I've never had this issue on my laptop nor desktop.
I'm wondering what is going on. It seems to happen regardless of what version of ubuntu I use. I'll get the following message:
Error message:
/dev/nvme0n1p5: recovering journal
/dev/nvme0n1p5: Superblock last mount time is in the future (by less than a day, probably due to hardware clock being incorrectly set)
/dev/nvme0n1p5: clean, 233072/1831424 files, 2190469/7324160 blocks
You are in emergency mode. After logging in, type "journalctl -xb" to view system logs, "system ctl reboot" to reboot, "systemctl default" or "exit" to boot  into default mode.
Press Enter for maintenance
(or Control-D to continue)
journalctl -xb does give me a log but its super long and I am not sure what information is pertinent.
I've tried running fsck but the commandline complains that the drive it is running on is mounted.
Most likely cause: Windows and Linux do not interpret System time the same way (UTC vs. local time). If this is the case, possible solutions consist of having both OSs interpret the system time the same way, either UTC or local time Clock time is off on dual boot.
Possible solutions:
  1. Set Windows to UTC, see "Make Windows use UTC" here.
    Please post in your question the exact location of file WindowsTimeFixUTC.reg in Windows. Then post in your question the exact contents of that file.
  2. Set Ubuntu to Local time, see "Make Linux use 'Local' time" here: timedatectl set-local-rtc 1 (you may need to add --adjust-system-clock).
    Please post in your question the exact output of
    $ timedatectl set-local-rtc 1
    $ timedatectl
  3. If hwclock gives you trouble, you might need this solution.
    $ hwclock --verbose
  4. Possibly not applicable, since it is for old Ubuntus. Edit /etc/default/rcS, change UTC=no to UTC=yes. Create the file if needed (source). You can also add another line with VERBOSE=yes.
  5. Idem. Edit /etc/default/rcS, change FSCKFIX=no to FSCKFIX=yes (perhaps a last resource).
  6. Verify that power to the internal clock is provided normally. As the Surface Go does not seem to have a CMOS battery, I am not sure about checking/fixing this. https://www.ifixit.com/Answers/View/153800/CMOS+backup+battery+inside+Surface
Sources / Related:
  1. https://serverfault.com/a/71625/326962 and other options in the same question
  2. Ubuntu 17.04 - Where is file /etc/default/rcS?
  3. https://ubuntuforums.org/showthread.php?t=2433546
