60
Using system settings I changed my language to Arabic and deleted the English language from the settings. Then the computer lagged and it logged out - now I can't log back in because the login is in Arabic.
So is there a way to default my language via terminal, default the login password language, or login via terminal which is still in English. I only have access to guest and a terminal.
I changed the pasword to something that could be translated into arabic http://www.psychocats.net/ubuntu/resetpassword - then loged in and used system settings to default.
Luis Alvarado
  • 216,643
McGee
  • 601
Edit two files:
  1. sudoedit /etc/default/locale:
    LANG="en_US"
    LANGUAGE="en_US:en"
  2. sudoedit ~/.pam_environment:
    LANG=en_US
    LANGUAGE=en_US
Logout and Login or Reboot.
Zanna
  • 72,312
In order to get back to English, I had to change my locale in 3 places:
  1. /etc/default/locale
    by running this command:
    $ sudo update-locale LANG=en_US.UTF-8 LANGUAGE= LC_MESSAGES= LC_COLLATE= LC_CTYPE=
  2. ~/.config/plasma-localerc and ~/.config/plasma-locale-settings.sh
    By going to my KDE settings / Regional Settings / Language
And reboot.
kolypto
  • 701
You can also do change the system language interactively using dpkg-reconfigure:
$ sudo dpkg-reconfigure locales
and follow the steps on the next screens.
After that, logout/login again and/or reboot.
Long
  • 123
s.k
  • 1,490
