34
Gvim does not have a global menu (appmenu / application menu) in 12.04, and when starting gvim from a terminal, the following warning appears in the terminal after 25 seconds:
** (gvim:20320): WARNING **: Unable to create Ubuntu Menu Proxy: Timeout was reached
How to fix this?
Jorge Castro
  • 73,717
5 Answers5
35
Solution 1: Make the global menu for gvim work
To get global menu for gvim and to get rid of the warning message, add this to ~/.bashrc and restart the terminal:
function gvim () { (/usr/bin/gvim -f "$@" &) }
Solution 2: Disable global menu for gvim
To just get rid of the warning message, you can disable the global menu, at least for gvim:
For example, add this to ~/.bashrc and restart the terminal:
alias gvim='UBUNTU_MENUPROXY= gvim'
References
There is a workaround here: https://bugs.launchpad.net/ubuntu/+source/vim/+bug/776499
Create an alias at the top of your shell init file (e.g. ~/.bashrc):
alias gvim="UBUNTU_MENUPROXY=0 gvim"
My Ubuntu 12.04 amd64 can work with gvim -f.
  • vim-gnome: 2:7.3.429-2ubuntu2.1+aptbuild1
  • terminator: 0.96-0ubuntu1+aptbuild1
  • guake: 0.4.2-7+aptbuild1
Chu-Siang Lai
  • 489
I can add the -f(--nofork) option when start gvim:
alias gvim="gvim -f"
This only works for gvim.
firefox and others don't have this -f option.
kev
  • 843
Another potential cause might be the ~/.gnome2/Vim file. This solution (which suggests that you delete ~/.gnome2/Vim) for the issue in Hardy Heron (before Unity) fixed the issue for me on Ubuntu 13.10.
For whatever reason, gvim -f didn't work for me.
Umang
  • 6,733
