I can't install Scilab.
When I ran sudo apt-get install scilab
there was output:
Reading package lists... Done
Building dependency tree
scilab : Depends: scilab-cli (>= 6.1.0+dfsg1-1ubuntu3) but it is not going to be installed
Depends: scilab-full-bin but it is not going to be installed
Recommends: scilab-doc (= 6.1.0+dfsg1-1ubuntu3) but 6.1.0+dfsg1-6build2 is to be installed
What can I do to solve this? please help. :)
