I have installed clean Ubuntu MATE 20.04 LTS and installed Scilab from repository here with
sudo apt-get update
sudo apt-get install scilab
After installation I tried to launch it from GUI (Applications → Other → Scilab) - it does not start.
Then I tried to launch it from terminal with scilab command. Terminal output is as follows:
$ scilab
Scilab cannot create Scilab Java Main-Class (we have not been able to find the main Scilab class. Check if the Scilab and thirdparty packages are available).
so it can't find Java again. I reported bug 1870813 about this problem. But as usual there is no reaction from package maintainers.
What should I do to get Scilab 6.1.0 working on Ubuntu 20.04 LTS?
N0rbert
  • 103,263
Scilab package for Ubuntu 20.04 seems to be broken, but you can always directly run it from the source.
  1. Download scilab from scilab website
cd ~/Downloads
wget https://www.scilab.org/download/6.1.0/scilab-6.1.0.bin.linux-x86_64.tar.gz
  1. extract the archive
tar xf scilab-6.1.0.bin.linux-x86_64.tar.gz
  1. run the file
./scilab-6.1.0/bin/scilab
Note: If you get following error:
error while loading shared libraries: libscilab-cli.so.6: cannot open shared object file: No such file or directory
run this command, taken from here
sudo ln -s /usr/lib/x86_64-linux-gnu/libtinfo.so.6 /usr/lib/x86_64-linux-gnu/libtinfo.so.5
It is known that Scilab is working normally in the Ubuntu 20.10, so one can download packages from it and install into the 20.04 LTS system:
mkdir -p ~/Downloads/scilab
cd ~/Downloads/scilab
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/s/scilab/scilab-cli_6.1.0+dfsg1-6build2_all.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/s/scilab/scilab-data_6.1.0+dfsg1-6build2_all.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/s/scilab/scilab-doc-fr_6.1.0+dfsg1-6build2_all.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/s/scilab/scilab-doc-ja_6.1.0+dfsg1-6build2_all.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/s/scilab/scilab-doc-pt-br_6.1.0+dfsg1-6build2_all.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/s/scilab/scilab-doc_6.1.0+dfsg1-6build2_all.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/s/scilab/scilab-full-bin_6.1.0+dfsg1-6build2_amd64.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/s/scilab/scilab-include_6.1.0+dfsg1-6build2_amd64.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/s/scilab/scilab-minimal-bin_6.1.0+dfsg1-6build2_amd64.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/s/scilab/scilab-test_6.1.0+dfsg1-6build2_all.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/s/scilab/scilab_6.1.0+dfsg1-6build2_all.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/h/hdf5/libhdf5-103-1_1.10.6+repack-2_amd64.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/h/hdf5/libhdf5-hl-100_1.10.6+repack-2_amd64.deb
wget -c http://archive.ubuntu.com/ubuntu/pool/universe/libm/libmatio/libmatio9_1.5.17-5_amd64.deb
sudo apt-get install ./lib*.deb
sudo apt-get install ./scilab*.deb
But anyway it is strange method, and the Scilab packages should be fixed on the repository level by its maintainers.
N0rbert
  • 103,263
