-1
I start by saying i am a noob in Linux systems and the only reason i need help is because i built a home server to have a bit more complex developing environment plus the obvious benefits like media server and file storage. I followed some online tutorials and everything was fine until yesterday when i installed cockpit in order to have some VM's running on it, when the system told me that there is no free space left. Therefore, i am sure something i did not do correctly since the SSD i have Ubuntu installed on has 256Gb, out of which, as far as i can see, only half is occupied. To put things in perspective, i have one more 256Gb SSD (sdb) + one 2Tb HDD which (sdc) which are logically fused into /mnt/cloud which i use as media server Can someone please guide me on how to fix this?
Thank you.
Result of df -i
Result for sudo lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL
Empusa
Your answer only points out df -i which only tells you about inodes, not really space left. However, df -h will respond with space used.
If you're unsure which folder takes the most space, run: sudo du -sh /* and enter deeper into the folders which seem to take the most.
My guess would be some logs were produced and eventually took too much space which I would expect to find either under /var folder or somewhere within the folder with your VM (probably your ~/ dir).
Jan Myszkier
  • 1,273
So basically the problem was exactly the one here: Ubuntu Server 18.04 LVM out of space with improper default partitioning
But i am still wondering why my sdb1 partition appears in my root Media folder
Empusa
