I can't seem to fix this bug, I tried searching for a solution for days now and can't find the solution to my particular problem, I hope if someone could help.
This error occurred after I was trying to downgrade my python==3.8 to python==3.7, but I had to stop the operation for some reason, later I also installed an SSD on my laptop(Inspiron 15 55575). When tried to set up my SSD I was unable to do anything since the same error kept on occurring.
These are some of the solutions I have tried.
- Can't upgrade due to low disk space on /boot
- Cannot Remove old Kernels from Full Boot Disk
- Regarding Too many errors in /usr/bin/dpkg returned an error code (1), How to easily remove old kernels in Ubuntu 20.04 LTS?
- Installing new kernel image - dpkg failing with permission error (20.04)
- unable to open '/boot/vmlinuz-5.8.0-43-generic.dpkg-new': Operation not permitted
- Ubuntu 18.04 remove all unused old kernels
- Problem in upgrade and install anyone
After running sudo apt full-upgrade that was suggested from some forums, this was the error I kept on getting.
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
Need to get 0 B/9,499 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up linux-image-5.8.0-48-generic (5.8.0-48.54~20.04.1) ...
Setting up grub-pc (2.04-1ubuntu26.9) ...
/var/lib/dpkg/info/grub-pc.config: 10: /etc/default/grub: splash: not found
dpkg: error processing package grub-pc (--configure):
installed grub-pc package post-installation script subprocess returned error exit statu
s 127
Setting up linux-image-5.8.0-44-generic (5.8.0-44.50~20.04.1) ...
Processing triggers for linux-image-5.8.0-48-generic (5.8.0-48.54~20.04.1) ...
/etc/kernel/postinst.d/dkms:
* dkms: running auto installation service for kernel 5.8.0-48-generic
...done.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.8.0-48-generic
/etc/kernel/postinst.d/zz-update-grub:
Sourcing file `/etc/default/grub'
/usr/sbin/grub-mkconfig: 10: /etc/default/grub: splash: not found
run-parts: /etc/kernel/postinst.d/zz-update-grub exited with return code 127
dpkg: error processing package linux-image-5.8.0-48-generic (--configure):
installed linux-image-5.8.0-48-generic package post-installation script subprocess retu
rned error exit status 1
Processing triggers for linux-image-5.8.0-44-generic (5.8.0-44.50~20.04.1) ...
* dkms: running auto installation service for kernel 5.8.0-44-generic
...done.
update-initramfs: Generating /boot/initrd.img-5.8.0-44-generic
dpkg: error processing package linux-image-5.8.0-44-generic (--configure):
installed linux-image-5.8.0-44-generic package post-installation script subprocess retu
grub-pc
and when running sudo apt-get upgrade.
The following packages will be REMOVED:
linux-image-5.8.0-41-generic
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 9,748 kB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 418768 files and directories currently installed.)
Removing linux-image-5.8.0-41-generic (5.8.0-41.46~20.04.1) ...
/etc/kernel/postrm.d/initramfs-tools:
update-initramfs: Deleting /boot/initrd.img-5.8.0-41-generic
/etc/kernel/postrm.d/zz-update-grub:
run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 127
dpkg: error processing package linux-image-5.8.0-41-generic (--remove):
installed linux-image-5.8.0-41-generic package post-removal script subprocess returned error exit status 1
dpkg: too many errors, stopping
Processing was halted because there were too many errors.
output of df-h
tmpfs 767M 2.2M 765M 1% /run
/dev/sda2 916G 264G 605G 31% /
tmpfs 3.8G 0 3.8G 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 3.8G 0 3.8G 0% /sys/fs/cgroup
/dev/loop1 56M 56M 0 100% /snap/core18/1997
/dev/loop0 185M 185M 0 100% /snap/blender/65
/dev/loop4 56M 56M 0 100% /snap/core18/1988
/dev/loop2 70M 70M 0 100% /snap/cherrytree/28
/dev/loop5 52M 52M 0 100% /snap/snap-store/518
/dev/loop6 273M 273M 0 100% /snap/telegram-desktop/2551
/dev/loop3 33M 33M 0 100% /snap/snapd/11107
/dev/loop7 2.3M 2.3M 0 100% /snap/gnome-system-monitor/157
/dev/loop8 219M 219M 0 100% /snap/gnome-3-34-1804/66
/dev/loop9 244M 244M 0 100% /snap/fakecam/102
/dev/loop13 2.3M 2.3M 0 100% /snap/gnome-system-monitor/148
/dev/loop12 76M 76M 0 100% /snap/discord/121
/dev/loop10 240M 240M 0 100% /snap/zoom-client/136
/dev/loop16 157M 157M 0 100% /snap/code/59
/dev/loop15 100M 100M 0 100% /snap/core/10908
/dev/loop14 241M 241M 0 100% /snap/zoom-client/138
/dev/loop17 65M 65M 0 100% /snap/gtk-common-themes/1513
/dev/loop11 21M 21M 0 100% /snap/ubuntu-make/845
/dev/loop19 162M 162M 0 100% /snap/gnome-3-28-1804/128
/dev/loop21 21M 21M 0 100% /snap/ubuntu-make/851
/dev/loop18 199M 199M 0 100% /snap/flutter/62
/dev/loop20 62M 62M 0 100% /snap/core20/904
/dev/loop22 398M 398M 0 100% /snap/datagrip/101
/dev/loop26 77M 77M 0 100% /snap/discord/122
/dev/loop24 33M 33M 0 100% /snap/snapd/11402
/dev/loop27 139M 139M 0 100% /snap/chromium/1514
/dev/loop23 244M 244M 0 100% /snap/fakecam/104
/dev/loop25 218M 218M 0 100% /snap/gnome-3-34-1804/60
/dev/loop29 163M 163M 0 100% /snap/gnome-3-28-1804/145
/dev/loop31 62M 62M 0 100% /snap/core20/875
/dev/loop28 52M 52M 0 100% /snap/snap-store/498
/dev/loop34 256K 256K 0 100% /snap/gtk2-common-themes/13
/dev/loop32 188M 188M 0 100% /snap/blender/111
/dev/loop35 139M 139M 0 100% /snap/chromium/1523
/dev/loop30 43M 43M 0 100% /snap/leafpad/79
/dev/loop37 65M 65M 0 100% /snap/gtk-common-themes/1514
/dev/loop39 199M 199M 0 100% /snap/flutter/56
/dev/loop36 153M 153M 0 100% /snap/code/58
/dev/loop33 395M 395M 0 100% /snap/datagrip/100
/dev/loop38 273M 273M 0 100% /snap/telegram-desktop/2480
/dev/loop40 100M 100M 0 100% /snap/core/10859
/dev/sda1 511M 7.9M 504M 2% /boot/efi
tmpfs 767M 16K 767M 1% /run/user/125
tmpfs 767M 36K 767M 1% /run/user/1000
I am currently using 5.8.0-43-generic
The links above are just some of the solutions, I have tried plenty but nothing worked for me, perhaps it's a hardware issue I suppose.
No matter what I tried nothing worked, I can't update my system, I can't set up my SSD, I can't do anything with apt or apt-get.
If more information is required please let me know, I will be active since this is an important issue for me, and I cant resume the work on my project unless I fix this.
