It was all working fine but after i did sudo apt upgrade i got a red dash icon on my notification bar and started facing conflicts with python versions,
when trying :
sudo apt upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libpython3.7 : Depends: libpython3.7-stdlib (= 3.7.10-1+bionic2) but 3.7.9-1+xenial1 is installed
libpython3.7-dev : Depends: libpython3.7-stdlib (= 3.7.10-1+bionic2) but 3.7.9-1+xenial1 is installed
libpython3.7-stdlib : Depends: libpython3.7-minimal (= 3.7.9-1+xenial1) but 3.7.10-1+bionic2 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
when i did :
sudo apt --fix-broken install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
python3.7-distutils python3.7-lib2to3
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libpython3.7-stdlib
The following packages will be upgraded:
libpython3.7-stdlib
1 upgraded, 0 newly installed, 0 to remove and 78 not upgraded.
57 not fully installed or removed.
Need to get 0 B/1,791 kB of archives.
After this operation, 10.2 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 211389 files and directories currently installed.)
Preparing to unpack .../libpython3.7-stdlib_3.7.10-1+bionic2_amd64.deb ...
Unpacking libpython3.7-stdlib:amd64 (3.7.10-1+bionic2) over (3.7.9-1+xenial1) ...
dpkg: error processing archive /var/cache/apt/archives/libpython3.7-stdlib_3.7.10-1+bionic2_amd64.deb (--unpack):
trying to overwrite '/usr/lib/python3.7/distutils/__init__.py', which is also in package python3.7-distutils 3.7.9-1+xenial1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
as requested in comment for
grep -r deb /etc/apt/sources.list /etc/apt/sources.list.d/
/etc/apt/sources.list:# deb cdrom:[Ubuntu 16.04.6 LTS _Xenial Xerus_ - Release amd64 (20190227)]/ xenial main restricted
/etc/apt/sources.list:deb http://in.archive.ubuntu.com/ubuntu/ bionic main restricted
/etc/apt/sources.list:# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial main restricted
/etc/apt/sources.list:deb http://in.archive.ubuntu.com/ubuntu/ bionic-updates main restricted
/etc/apt/sources.list:# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
/etc/apt/sources.list:deb http://in.archive.ubuntu.com/ubuntu/ bionic universe
/etc/apt/sources.list:# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial universe
/etc/apt/sources.list:deb http://in.archive.ubuntu.com/ubuntu/ bionic-updates universe
/etc/apt/sources.list:# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-updates universe
/etc/apt/sources.list:deb http://in.archive.ubuntu.com/ubuntu/ bionic multiverse
/etc/apt/sources.list:# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial multiverse
/etc/apt/sources.list:deb http://in.archive.ubuntu.com/ubuntu/ bionic-updates multiverse
/etc/apt/sources.list:# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-updates multiverse
/etc/apt/sources.list:deb http://in.archive.ubuntu.com/ubuntu/ bionic-backports main restricted universe multiverse
/etc/apt/sources.list:# deb-src http://in.archive.ubuntu.com/ubuntu/ xenial-backports main restricted universe multiverse
/etc/apt/sources.list:# deb http://archive.canonical.com/ubuntu xenial partner
/etc/apt/sources.list:# deb-src http://archive.canonical.com/ubuntu xenial partner
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu bionic-security main restricted
/etc/apt/sources.list:# deb-src http://security.ubuntu.com/ubuntu xenial-security main restricted
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu bionic-security universe
/etc/apt/sources.list:# deb-src http://security.ubuntu.com/ubuntu xenial-security universe
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu bionic-security multiverse
/etc/apt/sources.list:# deb-src http://security.ubuntu.com/ubuntu xenial-security multiverse
/etc/apt/sources.list:# deb https://dl.winehq.org/wine-builds/ubuntu/ focal main # disabled on upgrade to bionic
/etc/apt/sources.list:# deb-src https://dl.winehq.org/wine-builds/ubuntu/ focal main
/etc/apt/sources.list:deb http://dl.winehq.org/wine-builds/ubuntu/ bionic main
/etc/apt/sources.list:# deb-src http://dl.winehq.org/wine-builds/ubuntu/ bionic main
/etc/apt/sources.list:deb https://cloud.r-project.org/bin/linux/ubuntu bionic-cran40/
/etc/apt/sources.list:# deb-src https://cloud.r-project.org/bin/linux/ubuntu bionic-cran40/
/etc/apt/sources.list:deb http://us.archive.ubuntu.com/ubuntu/ artful-updates main
/etc/apt/sources.list:# deb-src http://us.archive.ubuntu.com/ubuntu/ artful-updates main
/etc/apt/sources.list:deb https://repos.codelite.org/ubuntu/ bionic universe
/etc/apt/sources.list:# deb-src https://repos.codelite.org/ubuntu/ bionic universe
/etc/apt/sources.list.d/sublime-text.list.distUpgrade:deb https://download.sublimetext.com/ apt/stable/
/etc/apt/sources.list.d/jonathonf-ubuntu-ffmpeg-4-xenial.list.save:# deb http://ppa.launchpad.net/jonathonf/ffmpeg-4/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/jonathonf-ubuntu-ffmpeg-4-xenial.list.save:# deb-src http://ppa.launchpad.net/jonathonf/ffmpeg-4/ubuntu xenial main
/etc/apt/sources.list.d/neovim-ppa-ubuntu-unstable-bionic.list.save:deb http://ppa.launchpad.net/neovim-ppa/unstable/ubuntu bionic main
/etc/apt/sources.list.d/neovim-ppa-ubuntu-unstable-bionic.list.save:# deb-src http://ppa.launchpad.net/neovim-ppa/unstable/ubuntu bionic main
/etc/apt/sources.list.d/sublime-text.list:# deb https://download.sublimetext.com/ apt/stable/ # disabled on upgrade to bionic
/etc/apt/sources.list.d/teejee2008-ubuntu-ppa-xenial.list:# deb http://ppa.launchpad.net/teejee2008/ppa/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/teejee2008-ubuntu-ppa-xenial.list:# deb-src http://ppa.launchpad.net/teejee2008/ppa/ubuntu xenial main
/etc/apt/sources.list.d/gnome-terminator-ubuntu-ppa-bionic.list:deb http://ppa.launchpad.net/gnome-terminator/ppa/ubuntu bionic main
/etc/apt/sources.list.d/gnome-terminator-ubuntu-ppa-bionic.list:# deb-src http://ppa.launchpad.net/gnome-terminator/ppa/ubuntu bionic main
/etc/apt/sources.list.d/webupd8team-ubuntu-java-xenial.list:# deb http://ppa.launchpad.net/webupd8team/java/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/webupd8team-ubuntu-java-xenial.list:# deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main
/etc/apt/sources.list.d/sublime-text.list.save:# deb https://download.sublimetext.com/ apt/stable/ # disabled on upgrade to bionic
/etc/apt/sources.list.d/google-chrome.list.save:deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
/etc/apt/sources.list.d/xenial-partner.list.distUpgrade:deb http://archive.canonical.com/ubuntu xenial partner
/etc/apt/sources.list.d/jonathonf-ubuntu-vim-xenial.list.distUpgrade:deb http://ppa.launchpad.net/jonathonf/vim/ubuntu xenial main
/etc/apt/sources.list.d/jonathonf-ubuntu-vim-xenial.list.distUpgrade:# deb-src http://ppa.launchpad.net/jonathonf/vim/ubuntu xenial main
/etc/apt/sources.list.d/jonathonf-ubuntu-ffmpeg-4-xenial.list.distUpgrade:deb http://ppa.launchpad.net/jonathonf/ffmpeg-4/ubuntu xenial main
/etc/apt/sources.list.d/jonathonf-ubuntu-ffmpeg-4-xenial.list.distUpgrade:# deb-src http://ppa.launchpad.net/jonathonf/ffmpeg-4/ubuntu xenial main
/etc/apt/sources.list.d/jonathonf-ubuntu-vim-bionic.list:# deb-src http://ppa.launchpad.net/jonathonf/vim/ubuntu bionic main
/etc/apt/sources.list.d/lutris.list.save:# deb http://download.opensuse.org/repositories/home:/strycore/Debian_10/ ./ # disabled on upgrade to bionic
/etc/apt/sources.list.d/wine-obs.list:# deb http://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_16.04 ./ # disabled on upgrade to bionic
/etc/apt/sources.list.d/jonathonf-ubuntu-vim-xenial.list:deb http://ppa.launchpad.net/jonathonf/vim/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/jonathonf-ubuntu-vim-xenial.list:# deb-src http://ppa.launchpad.net/jonathonf/vim/ubuntu xenial main
/etc/apt/sources.list.d/go-for-it-team-ubuntu-go-for-it-stable-xenial.list.save:# deb http://ppa.launchpad.net/go-for-it-team/go-for-it-stable/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/go-for-it-team-ubuntu-go-for-it-stable-xenial.list.save:# deb-src http://ppa.launchpad.net/go-for-it-team/go-for-it-stable/ubuntu xenial main
/etc/apt/sources.list.d/linrunner-ubuntu-tlp-xenial.list:# deb http://ppa.launchpad.net/linrunner/tlp/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/linrunner-ubuntu-tlp-xenial.list:# deb-src http://ppa.launchpad.net/linrunner/tlp/ubuntu xenial main
/etc/apt/sources.list.d/appgrid-stable.list.save:deb http://ppa.launchpad.net/appgrid/stable/ubuntu bionic main
/etc/apt/sources.list.d/mongodb-org-4.2.list:# deb [arch=amd64,arm64] https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/4.2 multiverse # disabled on upgrade to bionic
/etc/apt/sources.list.d/gnome-terminator-ubuntu-ppa-bionic.list.save:deb http://ppa.launchpad.net/gnome-terminator/ppa/ubuntu bionic main
/etc/apt/sources.list.d/gnome-terminator-ubuntu-ppa-bionic.list.save:# deb-src http://ppa.launchpad.net/gnome-terminator/ppa/ubuntu bionic main
/etc/apt/sources.list.d/neovim-ppa-ubuntu-stable-bionic.list:deb http://ppa.launchpad.net/neovim-ppa/stable/ubuntu bionic main
/etc/apt/sources.list.d/neovim-ppa-ubuntu-stable-bionic.list:# deb-src http://ppa.launchpad.net/neovim-ppa/stable/ubuntu bionic main
/etc/apt/sources.list.d/nodesource.list.save:# deb https://deb.nodesource.com/node_12.x bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/nodesource.list.save:# deb-src https://deb.nodesource.com/node_12.x bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/ondrej-ubuntu-php-xenial.list.save:# deb http://ppa.launchpad.net/ondrej/php/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/ondrej-ubuntu-php-xenial.list.save:# deb-src http://ppa.launchpad.net/ondrej/php/ubuntu xenial main
/etc/apt/sources.list.d/xenial-partner.list:deb http://archive.canonical.com/ubuntu bionic partner
/etc/apt/sources.list.d/appgrid-stable.list.distUpgrade:deb http://ppa.launchpad.net/appgrid/stable/ubuntu xenial main
/etc/apt/sources.list.d/neovim-ppa-ubuntu-stable-bionic.list.save:deb http://ppa.launchpad.net/neovim-ppa/stable/ubuntu bionic main
/etc/apt/sources.list.d/neovim-ppa-ubuntu-stable-bionic.list.save:# deb-src http://ppa.launchpad.net/neovim-ppa/stable/ubuntu bionic main
/etc/apt/sources.list.d/deadsnakes-ubuntu-ppa-xenial.list.distUpgrade:deb http://ppa.launchpad.net/deadsnakes/ppa/ubuntu xenial main
/etc/apt/sources.list.d/deadsnakes-ubuntu-ppa-xenial.list.distUpgrade:# deb-src http://ppa.launchpad.net/deadsnakes/ppa/ubuntu xenial main
/etc/apt/sources.list.d/nodesource.list.distUpgrade:deb https://deb.nodesource.com/node_12.x xenial main
/etc/apt/sources.list.d/nodesource.list.distUpgrade:deb-src https://deb.nodesource.com/node_12.x xenial main
/etc/apt/sources.list.d/lutris-team-ubuntu-lutris-xenial.list.save:# deb http://ppa.launchpad.net/lutris-team/lutris/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/lutris-team-ubuntu-lutris-xenial.list.save:# deb-src http://ppa.launchpad.net/lutris-team/lutris/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/lutris-team-ubuntu-lutris-xenial.list.save:# deb-src http://ppa.launchpad.net/lutris-team/lutris/ubuntu xenial main
/etc/apt/sources.list.d/ondrej-ubuntu-php-xenial.list:# deb http://ppa.launchpad.net/ondrej/php/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/ondrej-ubuntu-php-xenial.list:# deb-src http://ppa.launchpad.net/ondrej/php/ubuntu xenial main
/etc/apt/sources.list.d/lutris.list.distUpgrade:deb http://download.opensuse.org/repositories/home:/strycore/Debian_10/ ./
/etc/apt/sources.list.d/ondrej-ubuntu-php-xenial.list.distUpgrade:deb http://ppa.launchpad.net/ondrej/php/ubuntu xenial main
/etc/apt/sources.list.d/ondrej-ubuntu-php-xenial.list.distUpgrade:# deb-src http://ppa.launchpad.net/ondrej/php/ubuntu xenial main
/etc/apt/sources.list.d/deadsnakes-ubuntu-ppa-bionic.list.save:# deb-src http://ppa.launchpad.net/deadsnakes/ppa/ubuntu bionic main
/etc/apt/sources.list.d/mongodb-org-4.2.list.distUpgrade:deb [arch=amd64,arm64] https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/4.2 multiverse
/etc/apt/sources.list.d/go-for-it-team-ubuntu-go-for-it-stable-xenial.list:# deb http://ppa.launchpad.net/go-for-it-team/go-for-it-stable/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/go-for-it-team-ubuntu-go-for-it-stable-xenial.list:# deb-src http://ppa.launchpad.net/go-for-it-team/go-for-it-stable/ubuntu xenial main
/etc/apt/sources.list.d/nodesource.list:# deb https://deb.nodesource.com/node_12.x bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/nodesource.list:# deb-src https://deb.nodesource.com/node_12.x bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/webupd8team-ubuntu-java-xenial.list.save:# deb http://ppa.launchpad.net/webupd8team/java/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/webupd8team-ubuntu-java-xenial.list.save:# deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main
/etc/apt/sources.list.d/wine-obs.list.distUpgrade:deb http://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_16.04 ./
/etc/apt/sources.list.d/appgrid-stable.list:deb http://ppa.launchpad.net/appgrid/stable/ubuntu bionic main
/etc/apt/sources.list.d/google-chrome.list.distUpgrade:deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
/etc/apt/sources.list.d/jonathonf-ubuntu-vim-xenial.list.save:deb http://ppa.launchpad.net/jonathonf/vim/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/jonathonf-ubuntu-vim-xenial.list.save:# deb-src http://ppa.launchpad.net/jonathonf/vim/ubuntu xenial main
/etc/apt/sources.list.d/deadsnakes-ubuntu-ppa-xenial.list:deb http://ppa.launchpad.net/deadsnakes/ppa/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/deadsnakes-ubuntu-ppa-xenial.list:# deb-src http://ppa.launchpad.net/deadsnakes/ppa/ubuntu xenial main
/etc/apt/sources.list.d/linrunner-ubuntu-tlp-xenial.list.save:# deb http://ppa.launchpad.net/linrunner/tlp/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/linrunner-ubuntu-tlp-xenial.list.save:# deb-src http://ppa.launchpad.net/linrunner/tlp/ubuntu xenial main
/etc/apt/sources.list.d/linrunner-ubuntu-tlp-xenial.list.distUpgrade:deb http://ppa.launchpad.net/linrunner/tlp/ubuntu xenial main
/etc/apt/sources.list.d/linrunner-ubuntu-tlp-xenial.list.distUpgrade:# deb-src http://ppa.launchpad.net/linrunner/tlp/ubuntu xenial main
/etc/apt/sources.list.d/deadsnakes-ubuntu-ppa-xenial.list.save:deb http://ppa.launchpad.net/deadsnakes/ppa/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/deadsnakes-ubuntu-ppa-xenial.list.save:# deb-src http://ppa.launchpad.net/deadsnakes/ppa/ubuntu xenial main
/etc/apt/sources.list.d/lutris.list:# deb http://download.opensuse.org/repositories/home:/strycore/Debian_10/ ./ # disabled on upgrade to bionic
/etc/apt/sources.list.d/lutris-team-ubuntu-lutris-xenial.list.distUpgrade:deb http://ppa.launchpad.net/lutris-team/lutris/ubuntu xenial main
/etc/apt/sources.list.d/lutris-team-ubuntu-lutris-xenial.list.distUpgrade:deb-src http://ppa.launchpad.net/lutris-team/lutris/ubuntu xenial main
/etc/apt/sources.list.d/lutris-team-ubuntu-lutris-xenial.list.distUpgrade:# deb-src http://ppa.launchpad.net/lutris-team/lutris/ubuntu xenial main
/etc/apt/sources.list.d/wine-obs.list.save:# deb http://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_16.04 ./ # disabled on upgrade to bionic
/etc/apt/sources.list.d/neovim-ppa-ubuntu-unstable-bionic.list:deb http://ppa.launchpad.net/neovim-ppa/unstable/ubuntu bionic main
/etc/apt/sources.list.d/neovim-ppa-ubuntu-unstable-bionic.list:# deb-src http://ppa.launchpad.net/neovim-ppa/unstable/ubuntu bionic main
/etc/apt/sources.list.d/obs.list.save:deb https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/ ./
/etc/apt/sources.list.d/jonathonf-ubuntu-ffmpeg-4-xenial.list:# deb http://ppa.launchpad.net/jonathonf/ffmpeg-4/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/jonathonf-ubuntu-ffmpeg-4-xenial.list:# deb-src http://ppa.launchpad.net/jonathonf/ffmpeg-4/ubuntu xenial main
/etc/apt/sources.list.d/numix-ubuntu-ppa-bionic.list.save:deb http://ppa.launchpad.net/numix/ppa/ubuntu bionic main
/etc/apt/sources.list.d/numix-ubuntu-ppa-bionic.list.save:# deb-src http://ppa.launchpad.net/numix/ppa/ubuntu bionic main
/etc/apt/sources.list.d/teejee2008-ubuntu-ppa-xenial.list.distUpgrade:deb http://ppa.launchpad.net/teejee2008/ppa/ubuntu xenial main
/etc/apt/sources.list.d/teejee2008-ubuntu-ppa-xenial.list.distUpgrade:# deb-src http://ppa.launchpad.net/teejee2008/ppa/ubuntu xenial main
/etc/apt/sources.list.d/numix-ubuntu-ppa-bionic.list:deb http://ppa.launchpad.net/numix/ppa/ubuntu bionic main
/etc/apt/sources.list.d/numix-ubuntu-ppa-bionic.list:# deb-src http://ppa.launchpad.net/numix/ppa/ubuntu bionic main
/etc/apt/sources.list.d/lutris-team-ubuntu-lutris-xenial.list:# deb http://ppa.launchpad.net/lutris-team/lutris/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/lutris-team-ubuntu-lutris-xenial.list:# deb-src http://ppa.launchpad.net/lutris-team/lutris/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/lutris-team-ubuntu-lutris-xenial.list:# deb-src http://ppa.launchpad.net/lutris-team/lutris/ubuntu xenial main
/etc/apt/sources.list.d/jonathonf-ubuntu-vim-bionic.list.save:# deb-src http://ppa.launchpad.net/jonathonf/vim/ubuntu bionic main
/etc/apt/sources.list.d/obs.list:deb https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/ ./
/etc/apt/sources.list.d/webupd8team-ubuntu-java-xenial.list.distUpgrade:deb http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main
/etc/apt/sources.list.d/webupd8team-ubuntu-java-xenial.list.distUpgrade:# deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main
/etc/apt/sources.list.d/teejee2008-ubuntu-ppa-xenial.list.save:# deb http://ppa.launchpad.net/teejee2008/ppa/ubuntu bionic main # disabled on upgrade to bionic
/etc/apt/sources.list.d/teejee2008-ubuntu-ppa-xenial.list.save:# deb-src http://ppa.launchpad.net/teejee2008/ppa/ubuntu xenial main
/etc/apt/sources.list.d/xenial-partner.list.save:deb http://archive.canonical.com/ubuntu bionic partner
/etc/apt/sources.list.d/google-chrome.list:deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
/etc/apt/sources.list.d/mongodb-org-4.2.list.save:# deb [arch=amd64,arm64] https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/4.2 multiverse # disabled on upgrade to bionic
/etc/apt/sources.list.d/deadsnakes-ubuntu-ppa-bionic.list:# deb-src http://ppa.launchpad.net/deadsnakes/ppa/ubuntu bionic main
/etc/apt/sources.list.d/go-for-it-team-ubuntu-go-for-it-stable-xenial.list.distUpgrade:deb http://ppa.launchpad.net/go-for-it-team/go-for-it-stable/ubuntu xenial main
/etc/apt/sources.list.d/go-for-it-team-ubuntu-go-for-it-stable-xenial.list.distUpgrade:# deb-src http://ppa.launchpad.net/go-for-it-team/go-for-it-stable/ubuntu xenial main
sudo apt policy libpython3.7-stdlib
Installed: 3.7.9-1+xenial1
Candidate: 3.7.10-1+bionic2
Version table:
3.7.10-1+bionic2 500
500 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu bionic/main amd64 Packages
*** 3.7.9-1+xenial1 100
100 /var/lib/dpkg/status
3.7.5-2~18.04.4 500
500 http://in.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
3.7.0~b3-1 500
500 http://in.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
my source.list file:
cat /etc/apt/sources.list
See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
newer versions of the distribution.
Major bug fix updates produced after the final release of the
distribution.
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
Uncomment the following two lines to add software from Canonical's
'partner' repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
