I installed Ubuntu 20.04.2 LTS and I'm having problems with the audio, and I can;t understand the causes (it seems a bit random):
  1. Sometimes I can't hear anything when connecting to Zoom. It happens even if I just restarted the notebook. So I need to restart the computer again until it works.
  2. The microphone is constantly changing its level. Each time I plug or unplug, the levels are changed. And even if I set one level for each "profile" they change again, with no reason (usually for a higher value).
Can you help me? Any kind of trick here? EVen if it is a command that has worked for you to successfully restart the audio and not having to re-join the Zoom meetings I already joined?
Thanks in advance!
gal007
  • 376
