I have 2 versions of Ubuntu-Mate, 18.04 and 20.04.
This is my home directory for 20.04.
/media/andy/81353260-b5a5-4b72-9fce-432e7c620fdc/home/andy/
/etc/fstab: static file system information.
Use 'blkid' to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/sda2 during installation
UUID=5b4b2ae5-9aaa-4559-9f41-afb313998c75 / ext4 errors=remount-ro 0 1 /swapfile none swap sw 0 0
Is there a way I can change the name to a more user friendly and shorter name.
fixit7
  • 3,399
You could create an symlink in the /home directory of your 20.04 installation.
sudo ln -s /media/andy/81353260-b5a5-4b72-9fce-432e7c620fdc/home/andy /home/andy_1804
Then simply access your 18.04 "home" folder by using the shorter path "/home/andy_1804".
Enterprise
  • 12,792
The reason I wanted a shorter name for my home directory is I thought I would have to change some aliases that change directories.
One alias was alias dwn='cd /home/andy/Downloads'
But the actual directory is
/media/andy/81353260-b5a5-4b72-9fce-432e7c620fdc/home/andy/Downloads/
But the alias still works.
fixit7
  • 3,399
Run
  • lsblk to spot which partition holds the 20.04 install
  • blkid /dev/[what you found with sd* or nvme*n*p*] and copy the entire UUID=xx string (including the UUID= part)
  • mkdir whatever folder name you want in the /media/andy folder (ex. mkdir /media/andy/2004)
  • sudo nano /etc/fstab
  • Get at the end of the file and paste what I wrote in the code block and replace the UUID= and /media/andy/ part with yours
UUID=xxxxxx /media/andy/  ext4 rw,nofail,nosuid,nouser,auto,exec user 0 0
See man 5 fstab and man 8 mount to find docs about what I did
Reboot and normally you should be able to cd to your new directory and have your partition mounted
I had the same issue. Go to settings and then about. Change the Device Name and voilĂ .
