[This question has what I think is a duplicate here but I thought it would be worth providing another one with more detail)]
I'm trying to set up an external monitor to my laptop (Lenovo Thinkpad L380) but the HDMI port (there is only one on the laptop) is not being detected. I have a dual boot system and the same monitor+HDMI setup works fine on the Windows distro but not on Ubuntu. The Settings->Displays section does not show multiple displays and it turns out that xrandr is not detecting that there is a HDMI port at all. I have tried checking for available driver updates, changing display managers (between gdm3 and lightdm as suggested here) but to no avail, the HDMI port doesn't show up for xrandr:
$ xrandr --query
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected primary 1920x1080+0+0 0mm x 0mm
1920x1080 77.00*
nor using aplay:
$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC257 Analog [ALC257 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
My laptop is using the default Intel graphics card shown below:
$ sudo lshw -c video
*-display UNCLAIMED
description: VGA compatible controller
product: UHD Graphics 620
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 07
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list
configuration: latency=0
resources: memory:f0000000-f0ffffff memory:e0000000-efffffff ioport:e000(size=64) memory:c0000-dffff
The following is my xorg.conf file:
Section "Device"
Identifier "Intel"
Driver "intel"
# Option "AccelMethod" "uxa"
EndSection
For further info in case it's useful, here's the output of xrandr with the verbosity setting:
$ xrandr --verbose
default connected primary 1920x1080+0+0 (0x528) normal (normal) 0mm x 0mm
Identifier: 0x527
Timestamp: 12935
Subpixel: unknown
Clones:
CRTC: 0
CRTCs: 0
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
_MUTTER_PRESENTATION_OUTPUT: 0
non-desktop: 0
supported: 0, 1
1920x1080 (0x528) 159.667MHz *current
h: width 1920 start 0 end 0 total 1920 skew 0 clock 83.16KHz
v: height 1080 start 0 end 0 total 1080 clock 77.00Hz
and the sudo lspci -vnn output related to the VGA controller:
00:02.0 VGA compatible controller [0300]: Intel Corporation UHD Graphics 620 [8086:5917] (rev 07) (prog-if 00 [VGA controller])
Subsystem: Lenovo UHD Graphics 620 [17aa:506c]
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at f0000000 (64-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
I/O ports at e000 [disabled] [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] Process Address Space ID (PASID)
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [300] Page Request Interface (PRI)
Kernel modules: i915
I thought maybe the fact that I/O ports are disabled may have something to do with my problem?
