very bad and unpleasant sound quality. And the weird thing is- keeping volume 100% or below vanishes bad quality issue. However keeping volume at 100% or below, unusually produce very low volume sound which is tough to hear from a bit distant(abnormal). And as i increase volume after 100%, sound loudness increase drastically(pretty much like normal now), however bad sound+unwanted noise problem appear.
This problem started after not properly shutting down the pc(pulled power cable without shutting down). then few days later there was no sound at all. Today after reinstalling the os, the same bad sound problem showed up.
I tried this answer- Laptop's speakers sound bad. Poor sound quality
it didnt work. and also didnt find enable-lfe-remixing = no(2nd portion 4th line in that answer) in /etc/pulse/daemon.conf.
And from this answer- How do I debug issues with Pulse Audio? doing pulseaudio -D resulted in E: [pulseaudio] main.c: Daemon startup failed.
Tanzin
  • 23
