I had an unexpected system crash and when I came back, the sound wouldn't work on wired headphones or the built in speakers. (This is an Alienware 15r1.) The indicators in Settings->Sound show movement when I play audio files. I've tried both HDMI sound and the PCH sound, no luck. Here's what I've tried:
  • alsactl restore (as well as doing this with sudo)
  • purging and reinstalling alsa-base pulseaudio alsa-utils pulseaudio-utils pavucontrol
  • messing around in alsamixer
  • alsa force-reload
  • blowing up ~/.config/pulse
  • checking for missing drivers, kernel modules, etc
  • the procedure here: https://help.ubuntu.com/community/SoundTroubleshootingProcedure
The only weird thing I can see is this output from alsactl:
alsactl: state_lock:125: file /var/lib/alsa/asound.state lock error: File exists
alsactl: load_state:1683: Cannot open /var/lib/alsa/asound.state for reading: File exists
alsa-lib main.c:1021:(snd_use_case_mgr_open) error: failed to import hw:0 (empty configuration)
Found hardware: "HDA-Intel" "Intel Haswell HDMI" "HDA:80862807,80860101,00100000" "0x1028" "0x0685"
Hardware is initialized using a generic method
alsa-lib main.c:1021:(snd_use_case_mgr_open) error: failed to import hw:1 (empty configuration)
Found hardware: "HDA-Intel" "Creative CA0132" "HDA:11020011,10280685,00100918" "0x1028" "0x0685"
Here's my alsa-info output: http://alsa-project.org/db/?f=38c54b284f92305405593c1a6240699fbc94d455
Let me know if there's any other output you think is relevant.
Ben C
/var/lib/alsa/asound.state appears to be corrupted, empty or has permissions issues.
To fix this, run in the terminal:
sudo mv /var/lib/alsa/asound.state /var/lib/alsa/asound.state.old
then, run:
sudo alsactl --file /var/lib/alsa/asound.state store
then, run:
sudo alsa force-reload
then, run:
mv  ~/.config/pulse/ ~/.config/pulse_old/
then, run:
pulseaudio -k
or just reboot your system.
If that didn't work, check the alsamixer settings as in this answer then repeat the above steps.
Raffa
  • 34,963
Ultimately, after trying some more things I found here and elsewhere I ended up reinstalling from a Live CD.
Ben C
