I have a fresh installation of Ubuntu 12.04 x86 and I am trying to install the proprietary driver for my "Radeon HD 3200 Graphics" video card. I know that there are already many threads about this topic, but I did not find a solution for my problem:
For the installation I followed exactly these instructions: What is the correct way to install proprietary ATI Catalyst Video Drivers (fglrx) directly from AMD?
During the process I faced these problems: I executed
~$ debconf libstdc++6 dkms libqtgui4 wget execstack libelfg0 dh-modaliases
and got:
debconf: DbDriver "passwords" warning: could not open
/var/cache/debconf/passwords.dat: Keine Berechtigung
Can't exec "libstdc++6": Datei oder Verzeichnis nicht gefunden at
/usr/share/perl/5.14/IPC/Open3.pm line 186.
open2: exec of libstdc++6 dkms libqtgui4 wget execstack libelfg0 dh-modaliases failed
at /usr/share/perl5/Debconf/ConfModule.pm line 59
(translation of the German parts: "Keine Berechtigung" means: "no permission"; "Datei oder Verzeichnis nicht gefunden" means: "File or folder not found")
Because I had no idea if it was a big issue, I just continued:
~$ sudo apt-get install ia32-libs
There I got:
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut
Statusinformationen werden eingelesen... Fertig
Paket ia32-libs ist nicht verfügbar, wird aber von einem anderen Paket
referenziert. Das kann heißen, dass das Paket fehlt, dass es abgelöst
wurde oder nur aus einer anderen Quelle verfügbar ist.
E: Paket »ia32-libs« hat keinen Installationskandidaten
(Translation: [...] the package ia32-libs is not available but is referenced by an other package [...] E: package »ia32-libs« has no installation candidate)
Once more I went on. The next steps worked quite fine. But when I came to the point:
~$ sudo dpkg -i *.deb
There I got A popup message, something like
there was a problem with a system application
but in the terminal no errors were reported, also the packages seemed to be installed.
so now the Ati Catalyst Center works
amdcccle
but
fglrxinfo
gave me
X Error of failed request:  BadRequest (invalid request code or no such operation)
  Major opcode of failed request:  139 (ATIFGLEXTENSION)
  Minor opcode of failed request:  66 ()
  Serial number of failed request:  13
  Current serial number in output stream:  13
So there is something wrong. (Also there is not the possibility to enable these nice graphical features - the reason why I installed the proprietary driver)
Because I worked with a completely fresh Installation I don't know how to fix the problem. If anybody could help I would be very tahnkful! =)
samufi
  • 61
This line is tricky..
is actually a continuation on for the previous line. So it should be
sudo apt-get install build-essential cdbs fakeroot dh-make debhelper debconf libstdc++6 dkms libqtgui4 wget execstack libelfg0 dh-modaliases
in one line
Peachy
  • 7,235
  • 40
  • 47
zipc
