Ubuntu 18.04. I meant to click on eject and clicked on unmount. Now I can not use the DVD player. I tried reboot and I inserted and ejected the DVD a few times. Before when I put the DVD in it wound mount and display in browser and I could access the files on it. I have a Blu Ray player on same machine and it still works like this DVD drive used to. What do I need to do to fix this?
There is a Linux command called lsblk which will list all of the connected block devices regardless of if they are mounted or not.
From there you should be able to obtain the device name and then eject/mount it.
e.g.
#lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 55.5M 1 loop /var/lib/snapd/snap/core18/1988
loop2 7:2 0 71.4M 1 loop /var/lib/snapd/snap/lxd/19325
loop3 7:3 0 31.1M 1 loop /var/lib/snapd/snap/snapd/10707
loop4 7:4 0 55.4M 1 loop /var/lib/snapd/snap/core18/1944
loop5 7:5 0 31.1M 1 loop /var/lib/snapd/snap/snapd/11036
loop6 7:6 0 71.5M 1 loop /var/lib/snapd/snap/lxd/19389
sda 8:0 0 32G 0 disk
├─sda1 8:1 0 1G 0 part /boot
└─sda2 8:2 0 31G 0 part
├─cl-root 253:0 0 28.8G 0 lvm /
└─cl-swap 253:1 0 2.2G 0 lvm [SWAP]
sr0 11:0 1 1024M 0 rom
eject /dev/sr0
For adding in mount entries into /etc/fstab this link is very detailed..
https://www.cyberpratibha.com/use-of-fstab-option-for-mounting-disk-in-linux-permanent/
This one details automatic mouting of optical drives.
https://www.techrepublic.com/article/how-to-properly-automount-a-drive-in-ubuntu-linux/
- 1,575
As your using Nautilus you can try enabling the auto mount option using the dconf command.
This guide tells you how to disable it so follow the instructions and make sure that automount is ticked..
- 1,575
Turns out it was user error. Wrong labeled disk. Said it was a DVD and it turns out it was a Blu Ray. There is a Blu ray drive on the computer but that was not the one I was using.
- 2,316
- 2,316
