I installed Dash to Dock Extension on Ubuntu 20.10 But gradually my computer slowed down So I removed Dash to Dock and now Ubuntu Dock is Disappearing
How can I fix it?
How can I fix it?
Turn on the Ubuntu Dock extension using either "Gnome Tweaks" (gnome-tweak-tool or gnome-tweaks) or, on more recent versions of Ubuntu, "Extensions" (gnome-shell-extension-prefs). None of these utilities are installed by default on Ubuntu.
It is advised to reset the settings of the dock to the factory defaults. "Ubuntu Dock" uses the same settings as "Dash to Dock", so any configuration you did to the latter will carry on to the default dock. You can reset all dconf settings for Dash to dock with the command
dconf reset -f "/org/gnome/shell/extensions/dash-to-dock/"
You may need to log out and then back in to see things restored.
