-1
I want to transfer all my backed-up files(750GB) which are in a windows10 laptop to my freshly installed Ubuntu system. i have only got a 32GB pen drive and to transfer all the file using it will be a nightmare. Is there a way to connect the two machines?
Both my machines are connected to a router. My windows10 laptop is connected via wireless Wi-Fi and my Ubuntu PC is connected via an Ethernet cable. My PC doesn't have a wireless driver. Another recent problem is, my laptop Ethernet socket doesn't work.
yaa__
  • 771
If you have both computers connected to the same router, you can use:
  1. Ubuntu box as the server: Install openssh-server
    1.1. GUI applications: WinSCP, FileZilla
    1.2. Command line scp or (better) rsync from a Unix emulator in Win (that can be MingW, XMobaTerm, etc.)
    1.3. Powershell https://thedarksource.com/powershell-scp-to-transfer-files-between-windows-linux/
  2. Windows box as the server: (Will complete depending on your feedback)
If you want a direct connection, here you have a few links.
  1. https://unix.stackexchange.com/questions/251057/can-i-connect-a-ubuntu-linux-laptop-to-a-windows-10-laptop-via-ethernet-cable
  2. Transfer files from Windows to Linux via Ethernet cable
  3. https://superuser.com/questions/306682/how-do-i-connect-ubuntu-10-04-and-windows-7-with-an-ethernet-cable
  4. https://www.linuxquestions.org/questions/linux-networking-3/direct-connect-linux-to-win-via-ethernet-137098/
  5. https://linustechtips.com/topic/848807-possible-to-connect-windows-and-linux-pcs-via-ethernet/?tab=comments
