I need to transfer a backup that I have on windows 10 PC to a PC with Ubuntu MATE.
I read online that it is possible to do this with a LAN cable. I tried connecting the 2 PCs directly with the LAN cable, but I don't know how to check if they are really connected. And I don't know how to access the windows files from Linux.
Can somebody please explain me step by step how to do it?
Eliah Kagan
  • 119,640
Cicciopasticcio
  • 131
A reliable solution
  • get two ethernet cables and a router
  • connect the computers via the router
  • make the Ubuntu computer into an ssh server by installing openssh-server
  • make the Windows computer into an ssh client by installing WinSCP or Filezilla (in Windows)
  • connect via WinSCP or Filezilla and transfer the files. You can transfer a whole directory tree.
A direct connection with one single ethernet cable
The Windows end
You can find tutorials via the internet using a search string (without quotes) like "tutorial direct file transfer between two computers via ethernet", for example
https://techwiser.com/how-to-connect-pc-to-pc-lan-cable/
which describes what to do at the Windows end.
The Ubuntu end
You can find tutorials via the internet using a search string (without quotes) like "tutorial direct file transfer between two computers via ethernet linux" to find for example
https://www.softprayog.in/troubleshooting/connecting-two-computers-with-ethernet-lan-cable
which describes what to do at the Ubuntu end.
This is rather complicated, but on the other hand, you will learn a lot about networks.
sudodus
  • 47,684
Step one
I would not recommend to connect the both PCs directly, but rather put a router or a switch in between.
Step two
There are several ways to exchange data between a Linux and a Windows PC, such as Samba or others, but there is one which is really easy.
There is a Python package called magic-wormhole - https://magic-wormhole.readthedocs.io/en/latest/
Install it on both PCs and just do a wormhole send file on the one PC, and wormhole receive and the other one.
Rather than a wire (blue Ethernet cable) you can connect all devices over WiFi including Mac, Windows and Ubuntu. Here is one article on SSHFS:
Then you can use Nautilus to access the other computer. In my case I did this with my phone and from Nautilus (or the terminal) I can access my phone's files from Ubuntu.
