19
I'm running 12.04 inside VMWare Workstation.
What is wrong with my installation so that I cannot resize the window at the lower right corner? The lower left does work, albeit it's really hard to get it; upper left/right works OK, see this video:
http://www.youtube.com/watch?v=mMNItB0BN-8
Just to make it clear: this is not restricted to terminal, same with Firefox, synaptic, etc.
jobin
  • 28,567
mark
  • 1,072
7 Answers7
13
I have exactly the same issue, also running Ubuntu 12.04 in a VMware virtual machine. It's the same using VMware Fusion and VMware ESXi. It is also extremely difficult to grab any window edge, for example, to stretch the window horizontally or vertically.
The only solution I have found so far is to use the shortcut of holding down ALT and using the third button (usually middle) on the mouse if you have one. This will allow the window to be resized while the pointer is within that window's boundary, bypassing the need to grab the lower-right corner.
roobarb_
  • 146
I have found a few methods to solve this.
First, right clicking the title bar gives you a menu with re-size in it. Then whichever corner your pointer is closest to becomes a re-size handle which you then left click to end. This method only lets you be closest to the upper left and right corners however.
So... if you instead, use alt and a right click in the window, again you get a menu, but this way you can begin in the lower left or lower right of the window and then whichever you were closest to becomes the re-size handle. Then you re-size until satisfied, and then left click to release and keep the new size.
And lastly, since this menu show that alt-F8 is a shortcut, place the mouse pointer in the window closest to the corner you wish to re-size from and type alt-F8. When you release the keys, the mouse pointer will attach to the corner and you can re-size. Again, left click to end.
There is a bug report for the fact that on Unity 2D (which I think is being run in the video, and may be the only option in VMWare) the borders are very thin and difficult to grab, though why you should see this particularly on that corner I don't know.
https://bugs.launchpad.net/ubuntu/+source/metacity/+bug/878198
There is a workaround in comment #8. It may be that will fix the problem here.
clanlaw
  • 437
I have the same problem on default setup (just installed gnome-session-fallback) under VMware Player with Windows host OS.
The alt+middle click trick works. You can also resize on upper-left window corner.
Azarien
My problem was that the resize action was disabled in my compiz configuration. I solved it using Unable to resize windows
If you have been tweaking around with Compiz, this could have caused the problem. If not, login in with gnome classic, and see if it still has the same problem.
I am using Ubuntu on an ACER netbook, and Alt+F8 or right clicking the title bar weren't working for me. I didn't have a third mouse button but was able to shift the window up by using Alt+ double tap on my touch pad.
Anwar
  • 77,855
