When I did sudo apt-get update on the command line I found errors with "W: Target Packages"
sudo apt-get update
Hit:1 http://archive.canonical.com/ubuntu focal InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu focal InRelease
Get:3 http://security.ubuntu.com/ubuntu focal-security InRelease [109 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease [101 kB]
Hit:6 https://deb.nodesource.com/node_15.x focal InRelease
Ign:7 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/4.4 InRelease
Hit:8 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/4.4 Release
Hit:9 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal InRelease
Hit:10 http://lenovo.archive.canonical.com focal InRelease
Fetched 324 kB in 2s (142 kB/s)
Reading package lists... Done
W: Target Packages (multiverse/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/mongodb-org-4.4.list:1
W: Target Packages (multiverse/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/mongodb-org-4.4.list:1
W: Target Translations (multiverse/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/mongodb-org-4.4.list:1
W: Target Translations (multiverse/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/mongodb-org-4.4.list:1
W: Target DEP-11 (multiverse/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/mongodb-org-4.4.list:1
W: Target DEP-11 (multiverse/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/mongodb-org-4.4.list:1
W: Target DEP-11-icons-small (multiverse/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/mongodb-org-4.4.list:1
W: Target DEP-11-icons (multiverse/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/mongodb-org-4.4.list:1
W: Target DEP-11-icons-hidpi (multiverse/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/mongodb-org-4.4.list:1
W: Target CNF (multiverse/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/mongodb-org-4.4.list:1
W: Target CNF (multiverse/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/mongodb-org-4.4.list:1
I have tried
apt-get remove --purge mongodb
apt-get autoremove --purge mongodb
The result
~$ sudo apt-get purge mongodb-org*
Building dependency tree
Note, selecting 'mongodb-org-unstable-tools' for glob 'mongodb-org*'
Note, selecting 'mongodb-org-mongos' for glob 'mongodb-org*'
Note, selecting 'mongodb-org-tools' for glob 'mongodb-org*'
Note, selecting 'mongodb-org-unstable-server' for glob 'mongodb-org*'
Note, selecting 'mongodb-org-unstable-shell' for glob 'mongodb-org*'
Note, selecting 'mongodb-org-shell' for glob 'mongodb-org*'
Note, selecting 'mongodb-org-unstable-mongos' for glob 'mongodb-org*'
Note, selecting 'mongodb-org-unstable' for glob 'mongodb-org*'
Note, selecting 'mongodb-org' for glob 'mongodb-org*'
Note, selecting 'mongodb-org-server' for glob 'mongodb-org*'
Package 'mongodb-org-mongos' is not installed, so not removed
Package 'mongodb-org-shell' is not installed, so not removed
Package 'mongodb-org-tools' is not installed, so not removed
Package 'mongodb-org-unstable' is not installed, so not removed
Package 'mongodb-org-unstable-mongos' is not installed, so not removed
Package 'mongodb-org-unstable-server' is not installed, so not removed
Package 'mongodb-org-unstable-shell' is not installed, so not removed
Package 'mongodb-org-unstable-tools' is not installed, so not removed
The following package was automatically installed and is no longer required:
libcurl3
Use 'sudo apt autoremove' to remove it.
The following packages will be REMOVED:
mongodb-org* mongodb-org-server*
0 upgraded, 0 newly installed, 2 to remove and 21 not upgraded.
After this operation, 62.2 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 187143 files and directories currently installed.)
Removing mongodb-org-server (4.0.4) ...
Failed to stop mongod.service: Unit mongod.service not loaded.
invoke-rc.d: initscript mongod, action "stop" failed.
dpkg: error processing package mongodb-org-server (--remove):
installed mongodb-org-server package pre-removal script subprocess returned error exit status 5
mongodb-org-server
