My system is Ubuntu 20.04.2 LTS, Gnome version is 3.36.8.
I am going to Settings -> Keyboard Shortcuts.
Some keyboard shotcuts can be changed, while some are not.eg; "Switch to next input source" (for language switching). I press it, the pop up window says "Set Shotcut". If I press e. g. Alt+Tab, the system allows me to do that.
However if I want to do Alt+Shift (which is the classic one for language switching), the system does nothing.. Neither works Ctrl+Shift, Ctrl+Alt etc.
As far as I see, Alt+Shift is not assigned to any other other command. Please help..
Liker777
  • 145
It's correct, Settings does not currently accept those shortcuts.
But you can install gnome-tweaks, open Tweaks and use that mechanism for setting a shortcut for switching input language instead. Most of the shortcuts you mention are selectable there.
Not sure why it is like that.
And not sure for other restricted shortcuts.
However in particular for the Alt+Shift I have found a "manual" solution: alt + shift not work
sudo vim /etc/default/keyboard
Add or replace (if existing already) the following lines:
XKBVARIANT=""
XKBOPTIONS="grp:alt_shift_toggle"
Restart the computer
GAD3R
  • 3,748
Liker777
  • 145
