Laptop Model: . The bluetooth on my HP 250 G4 Notebook PC is working, but not detecting any device. I tried the following the steps suggested in this post, but it didn't work.
Results of systemctl | grep -i blue :
sys-devices-pci0000:00-0000:00:14.0-usb1-1\x2d4-1\x2d4:1.0-bluetooth-hci0.device loaded active plugged
/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/bluetooth/hci0
sys-subsystem-bluetooth-devices-hci0.device
loaded active plugged /sys/subsystem/bluetooth/devices/hci0
bluetooth.service
loaded active running Bluetooth service
bluetooth.target
loaded active active Bluetooth
Results of dmesg | grep -i blue :
[   19.734675] Bluetooth: Core ver 2.22
[   19.734721] Bluetooth: HCI device and connection manager initialized
[   19.734730] Bluetooth: HCI socket layer initialized
[   19.734735] Bluetooth: L2CAP socket layer initialized
[   19.734745] Bluetooth: SCO socket layer initialized
[   20.278547] Bluetooth: hci0: BCM: chip id 70
[   20.279542] Bluetooth: hci0: BCM: features 0x06
[   20.295596] Bluetooth: hci0: frodo
[   20.295605] Bluetooth: hci0: BCM43142A0 (001.001.011) build 0000
[   20.426538] Bluetooth: hci0: BCM: firmware Patch file not found
[   20.426550] Bluetooth: hci0: BCM: 'brcm/BCM43142A0-0a5c-216d.hcd'
[   20.426556] Bluetooth: hci0: BCM: 'brcm/BCM-0a5c-216d.hcd'
[   22.444638] Bluetooth: hci0: command 0x1003 tx timeout
[   22.445616] Bluetooth: hci0: unexpected event for opcode 0x1003
[   36.457400] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   36.457407] Bluetooth: BNEP filters: protocol multicast
[   36.457420] Bluetooth: BNEP socket layer initialized
[   38.924867] Bluetooth: hci0: command 0x1001 tx timeout
[   38.925773] Bluetooth: hci0: unexpected event for opcode 0x1001
[   53.284251] Bluetooth: RFCOMM TTY layer initialized
[   53.284259] Bluetooth: RFCOMM socket layer initialized
[   53.284267] Bluetooth: RFCOMM ver 1.11
karel
  • 122,292
  • 133
  • 301
  • 332
For other people that might have the same issue, I found the drivers at https://devid.info/ru/68560, by searching my laptop model and then I followed the instructions of the post that @Pilot6 mentioned in his answer: Bluetooth Broadcom 43142 isn't working
