Ubuntu 20.04
I have done a number of searches for ways to execute a script or command on resume from suspend, and come up with several different methods for doing this, such as what is described here - none of which worked for me.
The first method I found was using pm-utils. Apparently this method has been removed from Ubuntu, starting at or around 15.04
The next thing I found was to use systemd/system-sleep - this also didn't work for me. I tried creating a script in the /usr/lib/systemd/system-sleep directory, also tried the /lib/systemd/system-sleep directory (which is apparently linked to /usr/lib/systemd/system-sleep as changes in one appear in the other). I also tried modifying a script already present, called hdparm - this also didn't work (the modification I made was touch /tmp/xmodlog.log but the file never appeared).
So, can someone tell me what the correct way to run a script or command upon resume is?
Thanks for any input/suggestions/websites - especially ones with detailed instructions and explanations of what is happening along the way...
Edit:
Based on the answer provided by Matigo, I did the following:
In /etc/pm/sleep.d I created a script, called 00xmodkey.sh. I added the following script code into this file, then made sure it was owned by root, and that it had execute permissions.
Script contents (tried both sh and bash as the shell):
#!/bin/sh
case "${1}" in
resume|thaw)
echo "$(date) - lib testing" >> /tmp/xmodlog.log
esac
Verified ownership and permissions:
ls -l 00xmodkey.sh
-rwxr-xr-x 1 root root 257 Feb 4 22:49 00xmodkey.sh
Then I put the system into suspend. Waited `~20 seconds. Woke the system. Looked in /tmp for a file called xmodlog.log. No file.
So, I must still be missing something...
Edit 2:
Based on the response by blitzter47, I placed a script in /lib/systemd/system-sleep/ called 20xmodmap which I subsequently marked executable. The script file contained the following:
#!/bin/sh
# Remap a key to allow context menu access
case "$1" in
post)
echo "$(date) - $(1) $(2) - lib testing" >> /tmp/xmodlog.log
esac
exit 0
The file xmodlog.log never shows up in /tmp, so either something is wrong with the script, or the script is never being executed.
Edit 3:
Based on comments below, I changed the script to explicitly path the commands, and used touch rather than echo. No change in results. Also tried moving the location of the temporary file, just to make sure it wasn't something weird happening because of using /tmp, but again, no change. Here's the modified script:
#!/bin/sh
case "$1" in
post)
/bin/touch /home/tracy/xmodlog.log
esac
exit 0
So, even with everything explicitly pathed, and using a folder that I know my user has access to (system should have access to anything, if it's running in system context), it still doesn't seem to be working.
Edit 4:
Requested output from 'sudo systemctl status sleep.target suspend.target hibernate.target hybrid-sleep.target':
tracy@tracy-HP17:~$ sudo systemctl status sleep.target suspend.target hibernate.target hybrid-sleep.target
● sleep.target - Sleep
Loaded: loaded (/lib/systemd/system/sleep.target; static; vendor preset: e>
Active: inactive (dead)
Docs: man:systemd.special(7)
● suspend.target - Suspend
Loaded: loaded (/lib/systemd/system/suspend.target; static; vendor preset:>
● hibernate.target - Hibernate
Loaded: loaded (/lib/systemd/system/hibernate.target; static; vendor prese>
● hybrid-sleep.target - Hybrid Suspend+Hibernate
Loaded: loaded (/lib/systemd/system/hybrid-sleep.target; static; vendor pr>
Edit 5:
So, I went in and cleaned up the script, and made sure that everything is functional (running from the command line works). Here are the commands and the output from setting up and running the script:
tracy@tracy-HP17:/usr/lib/systemd/system-sleep$ which ls
/usr/bin/ls
tracy@tracy-HP17:/usr/lib/systemd/system-sleep$ which echo
/usr/bin/echo
tracy@tracy-HP17:/usr/lib/systemd/system-sleep$ ls -la /lib/systemd/system-sleep
total 32
drwxr-xr-x 2 root root 4096 Mar 9 21:30 .
drwxr-xr-x 17 root root 12288 Jan 19 13:39 ..
-rwxr-xr-x 1 root root 405 Mar 9 21:22 20xmodmap
-rwxr-xr-x 1 root root 148 Feb 26 22:01 hdparm
-rw-r--r-- 1 root root 404 Mar 9 20:54 holding.txt
-rwxr-xr-x 1 root root 219 Jul 21 2020 unattended-upgrades
tracy@tracy-HP17:/usr/lib/systemd/system-sleep$ nl 20xmodmap
1 #!/bin/sh
2 # Remap a key to allow context menu access
3 /usr/bin/ls /home/tracy/TestScript/
4 case "$1" in
5 post)
6 # /usr/bin/touch /home/tracy/TestScript/xmodlog.log
7 /usr/bin/echo "post" > /home/tracy/TestScript/xmodlog.log
8 ;;
9 *)
10 # /usr/bin/touch /home/tracy/TestScript/xmodlog.log
11 /usr/bin/echo "default" > /home/tracy/TestScript/xmodlog.log
12 ;;
13 esac
14 /usr/bin/ls /home/tracy/TestScript/
15 exit 0
tracy@tracy-HP17:/usr/lib/systemd/system-sleep$ ls /home/tracy/TestScript
tracy@tracy-HP17:/usr/lib/systemd/system-sleep$ sudo ./20xmodmap
[sudo] password for tracy:
xmodlog.log
xmodlog.log
tracy@tracy-HP17:/usr/lib/systemd/system-sleep$ nl /home/tracy/TestScript/xmodlog.log
1 default
tracy@tracy-HP17:/usr/lib/systemd/system-sleep$ rm /home/tracy/TestScript/xmodlog.log
rm: remove write-protected regular file '/home/tracy/TestScript/xmodlog.log'? y
Also, below are the last two lines (by time stamp) shown by journalctl from both before sleep and after resume:
Last two lines before sleep
tracy@tracy-HP17:/usr/lib/systemd/system-sleep$ journalctl -xe | grep 'sleep\|suspend'
Mar 09 21:30:21 tracy-HP17 sudo[132552]: tracy : TTY=pts/0 ; PWD=/usr/lib/systemd/system-sleep ; USER=root ; COMMAND=./20xmodmap
Mar 09 21:37:40 tracy-HP17 sudo[132821]: tracy : TTY=pts/0 ; PWD=/usr/lib/systemd/system-sleep ; USER=root ; COMMAND=./20xmodmap
Last two lines after resume
It appears that the script is not being run upon resume, as the output from journalctl both before and after are identical....
Edit 6:
OK, so based on a comment below by blitzter47, I dug deeper into what all is happening here from a power management standpoint. And it looks like I had some (incorrect) preconceptions of what was going on.
First, following the lead in the comment, issuing sudo systemctl suspend then waking the system does execute the script located in /lib/systemd/system-sleep, as indicated by the target file being created and containing the word "post". This is the first time (other than executing the script from the command line) that this has happened (and I am understandably excited that this progress is being made).
So, this led me to wonder what the difference was in that command, and what I had been doing. And after reading the article Understanding Suspend I believe what had been happening is that I was reaching the S1 state, but that the sudo systemctl suspend command was reaching the S3 state. Or, to put it another way, I was merely locking the screen, but not actually suspending the computer (except when the machine was untended for an extended period of time, which I will touch on in just a minute).
So, I went back over what I was actually trying to accomplish - which is to cause a particular keyboard shortcut to survive when the system "suspended". I had previously noted that there were some occasions where the keyboard shortcut would survive when I returned to the computer, and some occasions where it didn't, but I hadn't figured out exactly where that was coming from. Well, I now posit that the times it survived were the times when the system simply locked the screen (ie. reached the S1 state), but didn't actually suspend (ie. didn't reach S3 state). Whereas the times the keyboard shortcut didn't survive, the machine had actually reached the suspect (S3) state - possibly by being left undisturbed for a longer period of time.
So, the bottom line seems to be that system-sleep does work correctly for what I am trying to do (now that I actually understand what that is). So, my next step will be to actually update the script from Edit 5 (which is working correctly when I reach suspend (ie. S3 state)) with the command to restore my keyboard shortcut, then see if there are situations where the keyboard shortcut fails to survive, then re-evaluate what is happening at that point.
So, given all of this, I am going to mark blitzter47's original answer as accepted, and if/when I note that my keyboard shortcut doesn't survive a particular state, I will post a new question with (hopefully) a better idea of what the underlying cause is.
