I've been hours trying to solve this issue and can't figure out what else to do
When I do df -h, this is what I see:
Filesystem Size Used Avail Use% Mounted on
udev 7.8G 0 7.8G 0% /dev
tmpfs 1.6G 1.2M 1.6G 1% /run
/dev/mapper/ubuntu--vg-ubuntu--lv 8.8G 8.3G 129M 99% /
tmpfs 7.9G 16K 7.9G 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 7.9G 0 7.9G 0% /sys/fs/cgroup
/dev/sda2 976M 198M 712M 22% /boot
/dev/loop0 56M 56M 0 100% /snap/core18/1944
/dev/loop1 56M 56M 0 100% /snap/core18/1932
/dev/loop2 71M 71M 0 100% /snap/lxd/16922
/dev/loop4 32M 32M 0 100% /snap/snapd/10707
/dev/loop3 68M 68M 0 100% /snap/lxd/18150
/dev/loop5 32M 32M 0 100% /snap/snapd/10492
tmpfs 1.6G 0 1.6G 0% /run/user/1000
As you can see it is full, and I can't even do a mkdir
Apparenty there is a clean solution: Ubuntu Server 18.04 LVM out of space with improper default partitioning
I've done it but it shows the following:
LVM> lvextend -l +100%FREE `/dev/ubuntu-vg/ubuntu-lv`
New size (2303 extents) matches existing size (2303 extents).
As you can see This is doing nothing so I tried another thing:
Now I'm trying to make more space on the disk, but also having trubles doing that, I've made another post: https://forums.virtualbox.org/viewtopic.php?f=1&t=101457
Thank you in advantage
