I upgraded my Ubuntu OS on my laptop from 11.10 to 12.04, I did the Virtual Box work arounds mentioned in the thread: VirtualBox doesn't load after 12.04 upgrade, My Turnkey Linux VM's are back up and running now however my windows 7 VM has failed to come up. My whole laptop freezes and i have to force restart my laptop each time I try to start my windows 7 VM.
Is there a work around to ensure smooth startup and running of win 7 VM's
My virtual box version is 4.1.12_Ubuntu r77245
The probably-related VirtualBox bug ticket says it is fixed in VirtualBox source, and also details a workaround via grub.
https://www.virtualbox.org/ticket/10528
Hopefully the patch will be applied to Ubuntu-12.04 .
What are your Ubuntu and Windows versions (including 32 bit or 64 bit)?
I also had some problems when setting up VirtualBox 64 bit Windows machine on 32 bit Ubuntu, but everything works fine with 32 bit Windows.
f10w
  • 372
I had the same problem; 64bit version of Windows 7 machine on 32 bit Ubuntu 12.04. failing to startup with Virtualbox 4.1.14
This setup worked perfectly until I upgraded from Ubuntu 11.10 to 12.04
Removing and reinstall Virtualbox did not solve the problem:
    sudo apt-get remove Virtualbox-4.1
    sudo apt-get install Virtualbox-4.1
ALSO executing:
    sudo aptitude update
    sudo aptitude install dkms
    sudo /etc/init.d/vboxdrv setup
At last I created a 32bit version of Windows 7 machine and it works with fine without any problems.
Gunnar
