good morning,
lightdm freezes often after I entered my passwort. It hangs exactly saying "logging in...". It's no total system breakdown though.
I found out that there is already an existing bug report for that problem which affects a lot of people: https://bugs.launchpad.net/lightdm/+bug/986967
some people in Launchpad report that the problem may be caused by deactivating the login sound with Ubuntu Tweak. I've done that so it might be true.
There are 3 dupiclate question for this problem on askubuntu too:
Ubuntu 12.04 Hangs On Login
https://askubuntu.com/questions/130721/12-04-lightdm-cannot-login/130922#130922
https://askubuntu.com/questions/130387/stuck-at-login-screen
jobrfr
  • 783
i had the same problem, i installed gdm and logins in gdm than lightdm. light dm is a bug-gy. for this at main login crtl+alt+f1 and sudo there and apt-get install gdm and activate it
sam
  • 41
Until the official bugfix will be released - which should be soon - there are several ways to fix this problem:
  1. Reactivating the login sound with Ubuntu Tweak (worked for me)
  2. Installing the official bugfix which is in the "precise-proposed" repository now. https://wiki.ubuntu.com/Testing/EnableProposed
  3. Switching to gdm as default display manager as indicated by sam until this problem is fixed.
  4. Changing nothing and doing the following when the problem occurs:
    1. Pressing Ctrl + Alt + F1
    2. Logging in as admin user
    3. sudo restart lightdm
    4. Trying to login in lightdm again
    5. Repeating 1., 3. and 4. until the login is successful
(I did a bit of research and I'm now able to answer my question myself. I hope it's no problem)
htorque
  • 66,086
jobrfr
  • 783
I noticed that it is linked to custom wallpapers. I changed to a custom wallpaper and Ubuntu couldn't log in. It would simply hang at "logging in".
Following the steps above, changing the wallpaper back to a default, it works fine.
This should really be fixed.
Gonzoza
  • 2,528
I had the same issue after I added then removed the dodge feature from Unity (Ubuntu 12.04LTS 64bit)
This is what I did:
Using Synaptic Package Manager:
  1. Uninstalled Unity
  2. Uninstalled Lightdm
  3. Uninstalled Ubuntu-Desktop
  4. Re-installed Unity, Ubuntu-desktop, Lightdm
ALT + F2
unity --replace
I also reinstalled my Nvidia Graphic Drivers, has in the past caused issues after updates
Rebooted and it all came back working.
I did find I was able to log into a second account on my PC fine, so I think my profile was broken.
I then set my profile to auto logon in the USER menu.
I think it may have something to do with 'colord' (system service to manage device colour profiles), I noticed it kept crashing. Auto logon seems to be a solution, but compromises security..
The above process worked for me.
Thanks
pst007x
  • 8,210
