Had several issues with my wireless card.
After a reboot (i think after a kernel update) I could not see the network card in Network settings, but could see it using lspci.
Followed this guide Installing Broadcom Wireless Drivers
which suggests for my PCI.ID - 14e4:4331 (rev 02):
sudo apt install firmware-b43-installer
sudo apt install linux-firmware
which seems to have worked partially. Wifi works but only the 2.4GHz channel.
So I also tried the bcmwl-kernel-source.
It looks like the issue is with the bcmwl-kernel-source not compiling correctly on the latest kernel 5.8.0-7630-generic. (Get similar results when trying to install from 'Additional Drivers'):
administrator@ub-mbp:~$ sudo apt install bcmwl-kernel-source
[sudo] password for administrator:
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
  bcmwl-kernel-source
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/1,544 kB of archives.
After this operation, 8,068 kB of additional disk space will be used.
Selecting previously unselected package bcmwl-kernel-source.
(Reading database ... 401485 files and directories currently installed.)
Preparing to unpack .../bcmwl-kernel-source_6.30.223.271+bdcom-0ubuntu5_amd64.deb ...
Unpacking bcmwl-kernel-source (6.30.223.271+bdcom-0ubuntu5) ...
Setting up bcmwl-kernel-source (6.30.223.271+bdcom-0ubuntu5) ...
Loading new bcmwl-6.30.223.271+bdcom DKMS files...
Building for 5.8.0-7630-generic
Building for architecture x86_64
Building initial module for 5.8.0-7630-generic
ERROR (dkms apport): kernel package linux-headers-5.8.0-7630-generic is not supported
Error! Bad return status for module build on kernel: 5.8.0-7630-generic (x86_64)
Consult /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/make.log for more informati
on.
dpkg: error processing package bcmwl-kernel-source (--configure):
 installed bcmwl-kernel-source package post-installation script subprocess retur
ned error exit status 10
 bcmwl-kernel-source
output of /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/make.log
DKMS make.log for bcmwl-6.30.223.271+bdcom for kernel 5.8.0-7630-generic (x86_64)
Wed 06 Jan 2021 06:51:22 PM EST
make: Entering directory '/usr/src/linux-headers-5.8.0-7630-generic'
CFG80211 API is prefered for this kernel version
Using CFG80211 API
  AR      /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/built-in.a
  CC [M]  /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/shared/linux_osl.o
  CC [M]  /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.o
  CC [M]  /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_iw.o
  CC [M]  /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_cfg80211_hybrid.o
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/shared/linux_osl.c: In function ‘osl_reg_map’:
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/shared/linux_osl.c:949:10: error: implicit declaration of function ‘ioremap_nocache’; did you mean ‘ioremap_cache’? [-Werror=implicit-function-declaration]
  949 |  return (ioremap_nocache((unsigned long)pa, (unsigned long)size));
      |          ioremap_cache
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/shared/linux_osl.c:949:10: warning: returning ‘int’ from a function with return type ‘void *’ makes pointer from integer without a cast [-Wint-conversion]
cc1: some warnings being treated as errors
make[1]: *** [scripts/Makefile.build:288: /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/shared/linux_osl.o] Error 1
make[1]: *** Waiting for unfinished jobs....
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c: In function ‘wl_attach’:
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c:593:20: error: implicit declaration of function ‘ioremap_nocache’; did you mean ‘ioremap_cache’? [-Werror=implicit-function-declaration]
  593 |  if ((wl->regsva = ioremap_nocache(dev->base_addr, PCI_BAR0_WINSZ)) == NULL) {
      |                    ioremap_cache
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c:593:18: warning: assignment to ‘void *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c: In function ‘wl_pci_probe’:
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c:780:2: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]
  780 |  if ((val & 0x0000ff00) != 0)
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c:782:3: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
  782 |   bar1_size = pci_resource_len(pdev, 2);
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c:783:15: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
  783 |   bar1_addr = (uchar *)ioremap_nocache(pci_resource_start(pdev, 2),
In file included from /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_cfg80211_hybrid.c:40:
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_cfg80211_hybrid.c: In function ‘wl_set_auth_type’:
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_cfg80211_hybrid.h:52:5: warning: this statement may fall through [-Wimplicit-fallthrough=]
   52 |  if (wl_dbg_level & WL_DBG_DBG) {   \
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_cfg80211_hybrid.c:816:3: note: in expansion of macro ‘WL_DBG’
  816 |   WL_DBG(("network eap\n"));
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_cfg80211_hybrid.c:817:2: note: here
  817 |  default:
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c: In function ‘wl_reg_proc_entry’:
/var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c:3376:58: error: passing argument 4 of ‘proc_create_data’ from incompatible pointer type [-Werror=incompatible-pointer-types]
 3376 |  if ((wl->proc_entry = proc_create_data(tmp, 0644, NULL, &wl_fops, wl)) == NULL) {
      |                                                          const struct file_operations *
In file included from /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.c:38:
./include/linux/proc_fs.h:102:31: note: expected ‘const struct proc_ops *’ but argument is of type ‘const struct file_operations *’
  102 | extern struct proc_dir_entry *proc_create_data(const char *, umode_t,
make[1]: *** [scripts/Makefile.build:288: /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build/src/wl/sys/wl_linux.o] Error 1
make: *** [Makefile:1780: /var/lib/dkms/bcmwl/6.30.223.271+bdcom/build] Error 2
make: Leaving directory '/usr/src/linux-headers-5.8.0-7630-generic'
Anyway to fix this on this kernel?
Here is the results of lshw -class network if helpful:
*-network
       description: Wireless interface
       product: BCM4331 802.11a/b/g/n
       vendor: Broadcom Inc. and subsidiaries
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlp3s0b1
       version: 02
       serial: e0:f8:47:00:dd:02
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=b43 driverversion=5.8.0-7630-generic firmware=666.2 ip=192.168.0.54 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:17 memory:a0600000-a0603fff
As a temporary fix, I boot into the 5.4.0-59-generic kernel.
  1. During bootup, at the Grub screen, select option #2 (Advanced options for ubuntu).
  2. Then select the 3rd option ("Ubuntu, with Linux 5.8.0-34-generic)
After rebooting, your system should pick up the wifi adapter.
To make booting into the 5.4.0-39-generic the default option:
  1. sudo emacs /etc/default/grub # or use your favorite editor
  2. edit the GRUB_DEFAULT line to read GRUB_DEFAULT="1>2"
  3. save and exit the editor
  4. sudo update-grub
The GRUB_DEFAULT="1>2" tells the Grub menu to pick the 2nd option (counting from 0) on the first screen (i.e. "Advanced options for Ubuntu"), and then to pick the 3rd option on the 2nd screen (also counting from 0). You can either let the Grub screen timeout or press return twice and that should boot you into kernel version 5.4.0-39-generic.
As I said, this is my temporary fix. I think a permanent fix might involve a driver update from the vendor.
The default driver package included in Ubuntu repositories apparently can't be written to support each and any kernel version such as 5.8.0-7630. It does, however, support default Ubuntu kernel versions. For example, from my machine:
$ uname -r
5.8.0-34-generic
And:
$ sudo dpkg -s bcmwl-kernel-source
Package: bcmwl-kernel-source
Status: install ok installed
I suggest that you revert to a standard Ubuntu kernel and header version. The package should then install cleanly.
I will, however, be quite surprised if it then supports 5 gHz channels.
chili555
  • 61,330
What I did was just deleting the 5.8.0-34-generic kernel and it works completely fine now.
I haven't looked for any other solution, because I have a computer science project to finish in 2 days.
