So I have been struggling to set up my HP scanner/printer for a while now.
Trying to get hplip (as well as hplip-gui, hplip-setup, ...) through sudo apt-get install proved to be useless, cause it shows me that it's already installed, but when I try to access it, it claims it's not installed but could be installed through sudo apt-get install.
I then tried the manual installation through the installer on their website (a shell script called hplip-3.20.11-run), since this seems to be the favoured way of doing it. This one gives me the following output:
MISSING DEPENDENCIES
Following dependencies are not installed. HPLIP will not work if all REQUIRED dependencies are not installed and some of the HPLIP features will not work if OPTIONAL dependencies are not installed.
Package-Name Component Required/Optional
python3-notify2 gui_qt4 OPTIONAL
python3-pyqt4-dbus gui_qt4 OPTIONAL
python3-pyqt4 gui_qt4 REQUIRED
python3-dbus fax REQUIRED
python3-reportlab fax OPTIONAL
when I let the installer try to install these packages, I get:
RE-CHECKING DEPENDENCIES
error: A required dependency 'python3-pyqt4 (PyQt 4- Qt interface for Python (for Qt version 4.x))' is still missing.
error: A required dependency 'python3-dbus (Python DBus - Python bindings for DBus)' is still missing.
error: Installation cannot continue without these dependencies.
error: Please manually install this dependency and re-run this installer.
now when I try to do it via apt-get, it tells me these are already installed:
Reading package lists... Done
Building dependency tree
python3-pyqt4 is already the newest version (4.12.1+dfsg-2).
same for python3-dbus:
python3-dbus is already the newest version (1.2.6-1).
However I also can't find them using which python3-pyqt4 or which python3-dbus...
I assume there's some problem with finding these packages, but I don't know how to fix it?
EDIT: When I type apt-cache policy libcups2-dev cups-bsd cups-client avahi-utils gtk2-engines-pixbuf xsane python3-pyqt4 python3-dbus.mainloop.qt python3-notify2 as suggested below, I get:
libcups2-dev:
Installed: 2.2.7-1ubuntu2.8
Candidate: 2.2.7-1ubuntu2.8
Version table:
*** 2.2.7-1ubuntu2.8 500
500 http://de.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages
500 http://security.ubuntu.com/ubuntu bionic-security/main amd64 Packages
100 /var/lib/dpkg/status
2.2.7-1ubuntu2 500
500 http://de.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
cups-bsd:
Version table:
2.2.7-1ubuntu2 500
cups-client:
Version table:
2.2.7-1ubuntu2 500
avahi-utils:
Installed: 0.7-3.1ubuntu1.2
Candidate: 0.7-3.1ubuntu1.2
Version table:
*** 0.7-3.1ubuntu1.2 500
0.7-3.1ubuntu1 500
gtk2-engines-pixbuf:
Installed: 2.24.32-1ubuntu1
Candidate: 2.24.32-1ubuntu1
Version table:
*** 2.24.32-1ubuntu1 500
xsane:
Installed: 0.999-5ubuntu2
Candidate: 0.999-5ubuntu2
Version table:
*** 0.999-5ubuntu2 500
500 http://de.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
python3-pyqt4:
Installed: 4.12.1+dfsg-2
Candidate: 4.12.1+dfsg-2
Version table:
*** 4.12.1+dfsg-2 500
python3-dbus.mainloop.qt:
Version table:
python3-notify2:
Installed: 0.3-3
Candidate: 0.3-3
Version table:
*** 0.3-3 500
500 http://de.archive.ubuntu.com/ubuntu bionic/universe i386 Packages
to be precise again: The problem is that the installer fails due to these dependencies (also fails at installing them itself), even though they should be present.
EDIT2: output for which python:
/home/myusername/anaconda3/bin/python
output for which python2:
/usr/bin/python2
output for which python3:
/home/myusername/anaconda3/bin/python3
output for dpkg -l | grep python-is: nothing
