I have Toshiba satellite C50-A-1G6 PC which has a non recoverable Windows8.
When I try to install the Ubuntu 20.04 , from USB ISO file. It checks first my disks and says: no errors found. After selecting the language and the keyboard, I get error message: You need at least 8.6 GB disk space to install Ubuntu. This computer has only 4.1 GB. This computer has 750 GB hard disk.
The installation does not let met to go the part where I can choose the option, to clean up the entire hard disk and install only Ubuntu to it (I have done this many times earlier with broken Windows)
I am asking if somebody knows how I can prepare my hard disk with an .ISO application or in ‘try Ubuntu’ mode. Is there an other way to fix this with open source or a low price tool?
Below are the details:
There was Window 8 , which is broken and cannot be recovered with Windows 8 or 10 ISO installations , which I can download from the Microsoft site. Also I have tried MS-DOS Diskpart with the help I get from Google.
I can open Ubuntu in the "Try Ubuntu" mode and it works perfect and tried to fix with Boot-Repair from: https://help.ubuntu.com/community/Boot-Repair But it does not help, my problem stays.
When I run it I get the attached report. I don’t see any errors or fixes in it, The report is visible in https://paste.ubuntu.com/p/RNztvZzNzv/
Thanks for any help or hints.
KK Patel
  • 19,753
It looks like your HDD is dead. So you need to replace it first.
Pilot6
  • 92,041
Boot into BIOS and ensure your 750GB drive is visible. See: How to change boot priority? as a reference.
If it's visible in BIOS then try testdisk to see if it can be repaired. I could not find exact instructions. But I found related instructions here:
Step 1 - Boot on a liveCD or liveUSB
Boot your computer on a Ubuntu live-CD or live-USB, then choose "Try Ubuntu".
Step 2 - Install TestDisk in the live-session
Once in the Ubuntu live session, install TestDisk this way:
  • Connect internet
  • Open the Software Center, in the top bar click Edit -> Software Sources -> enable the Universe repository
  • Open a terminal (Ctrl+Alt+T) and type :
sudo apt-get update
sudo apt-get install -y testdisk && sudo testdisk
Step 3 - Use TestDisk
  • Via the arrows and the Enter key, go to the [No log] menu,
  • then select the disk where the broken partition is,
  • then select [Proceed],
  • then choose the type of partition (generally [Intel]),
  • then[Advanced],
  • then select the broken partition with [Boot], it will display something like :
 Boot sector
 Status: Bad
Backup boot sector Status: OK
Sectors are not identical.
A valid NTFS Boot sector must be present in order to access any data; even if the partition is not bootable.
[ List ] [Backup BS] [Rebuild BS] [ Dump ]
  1. Check that you have "Status ok" below "Backup boot sector"
  2. select [Backup BS].
Done
As mentioned these are not exact instructions. If you get stuck at a certain point when adapting these instructions to repair your disk, you can update your question.
