I'm trying to remap LCtrl and CapsLock on my Microsoft Wired Keyboard 600 with HWDB but for whatever reason the system does not see the changes that I make.
This is how my hwdb rule looks like:
evdev:input:b*v045Ep07F8*
KEYBOARD_KEY_3a=leftctrl
KEYBOARD_KEY_1d=capslock
The vendor and the model codes come from lsusb and were reconfirmed in /sys/devices/pci0000:00/*
After copying the config file to /etc/udev/hwdb.d, running systemd-hwdb update and issuing udevadm trigger no changes in the keyboard config are present.
I've also tried:
- Rebooting — didn't help.
- Specifying the bus explicitly as
0003— didn't help. - Confirming with
evtestthat the key codes I'm using are correct for my keyboard — yep, those are the correct keycodes. - Confirming the applied rules are listed in
sudo udevadm info /sys/class/input/eventX— yes, the new rules are listed, which should mean they were applied successfully? Yet the keys behave the same way they did before.
E: KEYBOARD_KEY_1d=capslock
E: KEYBOARD_KEY_3a=leftctrl
E: ID_USB_DRIVER=usbhid
When I use evdev:atkbd:dmi:* as the device identifier instead the change is correctly applied to my laptop keyboard so I know the rule and the process I'm using to remap the keys should be correct, it's got to be an issue with the wrong identifier (though I've quintuple checked it).
Any help will be appreciated.
