I recently bought a Jabra Elite 75t to connect to my computer. I did the following:
- Entered Pair Mode with my headphones
- Opened Settings -> Bluetooth
- Clicked on "Jabra Elite 75t" to pair the device
- Device was paired
When listening to youtube I intermittently get choppy audio with this device. I never experienced this with a wired setup before.
I tried the following fixes but nothing has worked; there is still some choppiness to it:
- A2DP on PulseAudio - terrible choppy/skipping audio
- https://www.reddit.com/r/Jabra/comments/j5489d/if_you_use_jabra_earbuds_with_linux_you_need_to/
The headphones seem to work fine on my Android phone, so I'm not sure what the issue is with Ubuntu (I'm on 20.04). This is the output from running lspci -knn | grep Net -A3; lsusb on my terminal:
00:14.3 Network controller [0280]: Intel Corporation Cannon Point-LP CNVi [Wireless-AC] [8086:9df0] (rev 30)
DeviceName: Onboard - Ethernet
Subsystem: Intel Corporation Cannon Point-LP CNVi [Wireless-AC] [8086:0034]
Kernel driver in use: iwlwifi
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp. 4-Port USB 3.1 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1532:0239 Razer USA, Ltd Razer Blade
Bus 001 Device 002: ID 13d3:56d5 IMC Networks Integrated Camera
Bus 001 Device 004: ID 8087:0aaa Intel Corp.
Bus 001 Device 008: ID 9636:9311
Bus 001 Device 007: ID 046d:c336 Logitech, Inc. 4-Port USB 2.1 Hub
Bus 001 Device 006: ID 1a40:0801 Terminus Technology Inc.
Bus 001 Device 005: ID 0bda:5411 Realtek Semiconductor Corp. 4-Port USB 2.1 Hub
Anything I'm doing wrong or advice on how to solve this?
