Logitech doesn't have an official driver for controlling the LED effects for Ubuntu. Is there any custom solution working (For example keyleds, openrgb, solaar, libratbag, anything else)?
Features that work out of the box:
- All the media buttons, game mode (disables the Win key), volume control. In other words, all the buttons work.
- Pressing ☀ cycles through brightness levels.
- Pressing ☀ + [NUM] (where [NUM] is 0, 1, 2, ..., 9) allows you to change the lightning effect on the fly.
- Pressing ☀ + - and ☀ + + changes the lightning effect speed for the non-custom effects.
Features that require setup
These require one-time setup with G HUB (connected through Lightspeed), then works everywhere you attach the keyboard to, including Linux:
- You can create custom lightning effects in the G HUB app (or download free lightning effects created by others from the G HUB) and then store two of them on the keyboard itself. The animations are accessible through ☀ + 8, ☀ + 9 (You can also set it to FN + F1, FN + F2, etc.)
- You can change the keyboard sleep timeout
Note: you might (not sure) need to activate the on-board mode for these to work fully. More on that below.
P.S. How to fix the reset to rainbow lightning effect after keyboard wakes up from sleep
Install G HUB (Windows or MacOS), connect keyboard with Lightspeed, go to Settings, and set ON-BOARD MEMORY MODE to ON. This is a one-time setup for the lifetime of a keyboard.
EDIT
There was an update to the GHub software and these are the new steps that allow for setting custom effects:
Create and name your lighting effect in Freestyle mode. Go to keyboard settings (a cog icon in the upper left corner) In the lower right corner of the settings add your named effect to the keyboard memory, but DO NOT switch to the onboard mode yet. Exit the settings and go back to lighting editor. In the editor, change effect type to preset instead of freestyle. Open the drop-down with presets and you'll see your own custom lighting at the bottom of the list. Select it. Only presets from this list can be stored as default in onboard mode. Now go back to settings, turn on the onboard mode and select your default profile, for which you've set your custom effect. (Credits to yawor)
There are some ways to control Logitech G915 TKL keyboard lighting in Linux Ubuntu:
You can use default settings available from keyboard, by using
*with any number from 0 - 9. It is working only temporary. After waking up keyboard from saving battery mode your chosen lighting will reset to default one.G Hub software - not useful too much on Linux, but I saw that people try different solutions using G Hub software on Windows and switching back to Linux. More info is on GitHub thread in g810-led project
You can use Ratbagctl project - It's solution that I use on my Logitech G915 TKL keyboard and it is working good for me. But you need to be careful. It writes configuration to onboard flash (it overwrites the stored profile on your keyboard). Some people after using it had problems with power saving settings. I did not.
You can use G810-led PR for G915 - It is the most flexible solution available right now, but I had the same problem like with default settings. After waking up keyboard from saving battery mode my setups were gone. There is a workaround for that, but I didn't try it. Ratbagctl was enough for me.
There is also Keyleds project, but for now I was only able to change gamemode setups using this tool.
Additionally, I wrote article about G915 TKL keyboard where I summarized those solutions in more details.
- 151
There is a g810-led project on GitHub. It does not explicitly support the G915, but it does support several other similar Logitech keyboards.
g810-led will allow you to save profiles specifying the color and brightness of individual keys.
The project doesn't appear to support any other features at this time.
If you are platform locked with Windows-only software from Logitech, you might also want to check with their documentation to see if it has on-board memory allowing you to keep your settings even when connected to a different PC or a different OS.
Also check to see if there is documentation for programming the keyboard using special key combinations without using any software.
It might not be possible to use features that are only available when using proprietary software if the manufacturer does not provide the software for Linux.
- 12,664
With G Hub, you can load your custom lighting and inactivity setup as the default profile (replacing the rainbow) with the « onboard mode ». Then you can use it with Ubuntu or any other computer and it will stay as the keyboard's default profile. I just wrote a tutorial about it : https://medium.com/@alexis.j.boix/logitech-g915-onboard-custom-lightning-f9afb550c678
- 111
I've a simple solution that should work out of the box (using Ubuntu 18.04 LTS):
Simple press the brightness button (-0-) + 0 (which translates to the Preset 'Fixed' if you were to install Ghub on win 10 for e.g.).
This essentially stops all 'cycling' and animations which can be quite distracting if you are coding and not playing games.
- 191
A Quick fix that worked for me is to use openrgb for linux. (Ubuntu 24.04.2 LTS)
Download OpenRGB 0.9 (Stable) // use :
Linux (Debian Bookworm 64-bit .deb)Rename it to "openrgb_0.9.deb" then install with:
sudo apt install ./openrgb_0.9.debRun :
openrgb, set the lightening effect as you like, save a profile "profilename"Run :
while sleep 5; do openrgb --noautoconnect -p profilename; done
Ctrl + Cat the terminal will stop the loop.
(remember to change the profile name to your profilename you saved on openrgb gui)
Note: By setting as low as 5 seconds sleep time ll do fine due to the keyboard always going back to his own lightening setting on: inactivity event and sleep to save power event.
So probably that ll do the job until you have access to "G hub software" (Windows OS only)
- 1
- 1
