40
Ubuntu 20.04 won't wake up from sleep
Issue:
  • Whenever the laptop suspends (either due to a closed lid or due to a black screen for a certain time), I cannot wake it up.
  • The laptop does not respond to keystrokes and power button clicks. As a result, I always have to hold the power button to shut it down and then power it up again.
System:
  • Model: Dell Inspiron 15 3593
  • Processor: Intel® Core™ i5-1035G1 CPU @ 1.00GHz × 8
  • Graphics: Mesa Intel® UHD Graphics (ICL GT1)
  • RAM: 16GB DDR4
  • Storage: 512GB SSD + 1TB HDD
  • OS: Ubuntu 20.04 LTS 64bit
Extra info:
Thank you in advance!
Update:
  • Tried GRUB_CMD_LINUX="nouveau.modeset=0" in grub config and it didn't work.
  • Tried GRUB_CMDLINE_LINUX="nouveau.blacklist=1" in grub config and it didn't work.
  • I switched to an old kernel version: 5.0.0-1070-oem-osp1 and made it the default choice because under this kernel the issue is resolved.
  • I used this guide for changing the default kernel: How can I boot with an older kernel version? . Thank you @B.Tanner for the idea. I really hope that it will be fixed for newer Kernels in the future.
  • Reported bug here: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1909005
1618
  • 511
12 Answers12
13
With Dell notebooks I generally configure them like this:
  1. Open the terminal
  2. Install the necessary drivers with ubuntu-drivers autoinstall
  3. Disable the fallback service with sudo systemctl disable nvidia-fallback.service
  4. Then edit /etc/default/grub and add the line: GRUB_CMDLINE_LINUX="nouveau.blacklist=1"
  5. Update Grub with: sudo update-grub
  6. Reboot
With this my colleagues can suspend/hibernate-resume without too many issues … though there are occasional hiccups for people who suspend for 4+ days.
Hope this works for you, too
This fixed it for me (found after searching for "suspend" in journalctl -r). Final solution posted by apienk to remove damaged symlinks: https://bugs.launchpad.net/ubuntu/+source/systemd/+bug/1933880
I hope it helps someone
Simon
  • 71
I know that this is an old post, but I frequented this constantly over the last few weeks trying to find an answer and I thought hopefully someone else will come along like me and see this instead.
In Terminal I ran uname -sr and it returned Linux 5.13.0XXXXXXX-generic I then went to here and scrolled down to the bottom.
This is the different updates for Ubuntu. I ignored the rc* files, and found the most recent, which in my case was v5.15/
When you click on that folder, you want to download the amd64 sets. Which is the first set of links. You want:
amd64/linux-headers-5.15.0-051500-generic_5.15.0-051500.202110312130_amd64.deb
amd64/linux-headers-5.15.0-051500_5.15.0-051500.202110312130_all.deb
amd64/linux-image-unsigned-5.15.0-051500-generic_5.15.0-051500.202110312130_amd64.deb
amd64/linux-modules-5.15.0-051500-generic_5.15.0-051500.202110312130_amd64.deb
You'll notice that all of these names have 'generic' in them instead of 'low latency', except for the one that contains 'all'.
Download those files, and chuck them in a folder. For simplicity I had them under Documents/kernels/5.15/
(I created these folders, they don't already exist aside from Documents).
I then went cd Documents/kernels/5.15/ followed by sudo dpkg -i *.deb This installs all of those files you just downloaded. Make sure you're in the correct folder, or *.deb will install any file with that suffix.
It will take a few minutes to install. Once installed I wanted to check that it had been installed.
apt list --installed | grep linux-image You should get a list of the currently installed versions. For me I had two 5.13's and my newly installed 5.15
At this point I uninstalled 5.13 with sudo apt remove linux-image-5.13.0-19-generic (you will of course have to replace the 5.13.0-19 with whatever version you are running). If you are uncomfortable uninstalling, you can wait or not do it at all. It's not a necessary step.
sudo reboot
At this point, if you do not usually start with a boot to GRUB, hold down your SHIFT key. Under Advanced Options, I manually selected 5.15
I was told that I had an invalid signature. To fix this, I ran 5.13 again, then rebooted, went into the GRUB settings, and located a way to disable Secure Boot. Each laptop will be different so I'm sorry I can't be more help here, but the settings should be fairly easy to navigate.
Feel free to do your own research on whether or not you should disable Secure Boot. Don't listen to strange people on the internet.
With secure boot disabled, I could launch 5.15, I tested it several times, and my suspend issues were over!
Hopefully this helps anyone else.
Mono
  • 31
what worked for me:
sudo systemctl disable nvidia-suspend
which leads to the output:
Removed /etc/systemd/system/systemd-suspend.service.requires/nvidia-suspend.service.
Some more comments about it: ubuntu-20-04-with-nvidia-460-driver-freezes-randomly-after-resume-from-suspend-hibernate
I'm having very similar problem with the difference of these specs
  • Model: Dell Latitude 5490
  • Processor: Intel® Core™ i5-8250U
After a long time searching online and trying different unsuccessful fixes I've found this article where @davze assumes that:
Kaby Lake processors seem to have problems with C-States on recent kernels
and proposes limiting c-states. Your CPU family seems to be different
(Ice Lake), but you can try it too, adding
acpi_enforce_resources=lax i915.enable_dc=0 intel_idle.max_cstate=1
to GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub. Run sudo update-grub and reboot to see the effect. Now my system can suspend and wake up properly, but unfortunately as the author of the article has mentioned: Limiting the cstates is of course killing the battery....
PS:
acpi_enforce_resources - allows access to resources claimed by ACPI read more
i915.enable_dc=0 - disables GPU power management
intel_idle.max_cstate=1 - limits allowed c-states read more
I was struggling with the same issue on my new Dell Inspiron Laptop. I found a way to make sleep to RAM work as it should on my Kubuntu 21.10 system.
You have to recompile the DSDT (Differentiated System Description Table) which is part of the ACPI managagement module which manages power related events.
Here is a blog post including instructions:
https://dev.to/epassaro/fix-suspend-issues-on-dell-7405-2-in-1-3l1b
According to the author of that blog post, the DSDT seems to be compiled for Windows out-of-box and deactivates sleep to RAM (S3). Instead, it assumes usage of "modern/connected standby" (S0ix) that Windows uses. Apparently some AMD CPUs may not support this on Linux. As the blog post suggests run:
$ sudo dmesg | grep -i acpi | grep supports
The output should look something like this:
[    0.357470] ACPI: (supports S0 S4 S5)
If you don't see S3 for sleep to RAM there, the instructions in the blog post may help you activate sleep to RAM (S3).
Addendum: On a Lenovo P14s running Ubuntu 20.04 LTS with an AMD Ryzen 7 pro 5850u, this problem also occurred. In Step 2 of the instructions, recompiling dsdt.dsl did not show any errors for me but I could simply skip that step.
Also, in Step 3 of the given instructions where the dsdt.dsl is modified, I could not find the exact piece of code the author suggests to replace. Instead my dsdt.dsl contained the following lines (searching the file for "System State" showed the according active entries for S0, S4 and S5 for me; the deactivated S3 entry was located in that part of the file):
Name (NOS3, Package (0x04)
    0x03,
    0x03,
    0x00,
    0x00
However, replacing those lines by the following lines suggested by the author also worked to activate S3 for me:
Name (_S3, Package (0x04)  // _S3_: S3 System State
    0x03,
    0x03,
    Zero,
    Zero
nvidia-driver-510(propriertary) worked for me.
Syed Kazmi
  • 13
I had the same problem, I have a Lenovo AMD A9 with Ubuntu 20.04, the problem started when the power and the capital letter indicator in my keyboard doesn't turned off, after that the pc doesn't turn off totally, then some times don't booted the ubuntu, and another times started. Finally, when the PC turned on, the pc showed me a black display blinking and never started.
I installed 5 times the ubuntu 20.04 and It don't worked, I installed ubuntu 21.10 and again nothing. Finally, I created the USB bootable using this steps (https://www.linuxtechi.com/create-bootable-usb-disk-dvd-ubuntu-linux-mint/), but using ubuntu-18.04-desktop-amd64.iso (be carefull because some ISO images are bad), and I used the "Make startup Disk" in Ubuntu, I booted the pc and I installed totally the ubuntu 18.04, after that my pc worked fine, with afraid update the ubuntu to 20.04 version, but the computer worked fine.
That was my experience, and I write with detail because I am not developers, only a normal user, and I saw many blog and foros, but with a specializaed language. So I hope that can be help.
Here's a hack i have found out. It works for me.
Whenever you want to suspend your PC just keep any App pr Tab Open on Screen (Like browser, any app).
Don't suspend on desktop screen. (If you suspend on Home Screen(Desktop Screen) then you won't be able to see the desktop screen after waking up, though your CPU will be ON.
If it works for you kindly let me know.
My solution is not for everyone, but let me share the solution here.
Targets
  1. Those who do not want to use suspend/hibernation (block them from the setting), and
  2. those who only use sleep mode and no suspend/hibernation.
Under those conditions, my solution works nicely. Basically, we need to prevent our laptop from going suspend/hibernation. We can achieve it by the following:
  1. Run sudo emacs /etc/systemd/logind.conf and edit the file as stated next,
  2. Edit HandleLidSwitch and HandleLidSwitchExternalPower to HandleLidSwitch=ignore and HandleLidSwitchExternalPower=ignore, (Do not forget to remove # as well)
  3. Reboot your laptop, and
  4. Check the variable by busctl get-property org.freedesktop.login1 /org/freedesktop/login1 org.freedesktop.login1.Manager XXX (XXX must be replaced with either HandleLidSwitch or HandleLidSwitchExternalPower and the output should be ignored, but not suspend).
Then it resolved the issue in my case as I do not need the hibernation anyways.
About the kernel version, it also resolved my issue, but since other hardwares were affected by the change, I could not take this solution.
I hope it helps someone.
Enabling "Switchable Graphics" in the BIOS fixed it for me (previously it was set to only use the discrete graphics card, which in my case is NVIDIA).
obe
  • 287
I recently got a new HP Probook G11 with Ryzen 5 7535U with Radeon R680m integrated graphics. I had the same problem of screen not turning back on after suspend or sleep. I found a solution by setting
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash processor.max_cstate=1 idle=nomwait amdgpu.aspm=0"
in the grub from \etc\default\grub. The screen freezing issue has disappeared for now :)
Rebantadey
