I have recovered 1TB external hard disk using DD-Rescue-GUI. The image is stored in a 2TB external hard disk. I tried to mount it but could not succeed. I also tried the solution in the Mounting Disk Image in Raw format, and getting the below result.
In the below script, the parameter for -o in the line sudo losetup -o 991369929728 is calculated as per the above link, i.e., 512 bytes * Starting sector = 512 * 1936269394 = 991369929728
rauf@rauf-Latitude-E5420:~$ sudo fdisk -lu /media/rauf/My\ Passport/Old\ 1\ TB\ Disk/onetb.img
[sudo] password for rauf:
Disk /media/rauf/My Passport/Old 1 TB Disk/onetb.img: 931.49 GiB, 1000169537536 bytes, 1953456128 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x6e697373`
Device Boot Start End Sectors Size Id Type /media/rauf/My Passport/Old 1 TB Disk/onetb.img1 1936269394 3772285809 1836016416 875.5G 4f QNX4.x 3rd part /media/rauf/My Passport/Old 1 TB Disk/onetb.img2 1917848077 2462285169 544437093 259.6G 73 unknown /media/rauf/My Passport/Old 1 TB Disk/onetb.img3 1818575915 2362751050 544175136 259.5G 2b unknown /media/rauf/My Passport/Old 1 TB Disk/onetb.img4 2844524554 2844579527 54974 26.9M 61 SpeedStor
Partition table entries are not in disk order. rauf@rauf-Latitude-E5420:~$ sudo losetup -o 991369929728 /media/rauf/My\ Passport/Old\ 1\ TB\ Disk/onetb.img losetup: /media/rauf/My Passport/Old 1 TB Disk/onetb.img: failed to use device: No such device rauf@rauf-Latitude-E5420:~$ sudo losetup -o 991369929728 /media/rauf/My\ Passport/Old\ 1\ TB\ Disk/onetb.img losetup: /media/rauf/My Passport/Old 1 TB Disk/onetb.img: failed to use device: No such device rauf@rauf-Latitude-E5420:~$
Rauf
  • 131
You have to use the kpartx utility.
Attach the partitions to loop-devices with:
sudo kpartx -a -v onetb.img
and then use devices from /dev/mapper/....
N0rbert
  • 103,263
