I'm running Ubuntu 20.04 on a laptop with a function key Fn that I use for volume and brightness control.
Whenever I increase the brightness of the screen by the shortcut Fn+, the screen increases in brightness but I also get a symbol “±” outputted.
E.g., I'm in the terminal environment, I increase the brightness and a “±” is deposited in my terminal.
I do not have this problem with any of the other shortcut keys that use the function key. Is there any way to stop this from happening?
The only shortcuts in Ubuntu I can find are in the system settings “Settings → Keyboard Shortcuts”, which do not include this instance.
Edit: I found in this question that there is a program xev which is an event monitor for mouse and keyboard. When I press and release the key combination Fn+, I get the following output from xev:
KeyPress event, serial 38, synthetic NO, window 0x4400001,
    root 0x6a9, subw 0x0, time 10913753, (1291,-68), root:(1342,47),
    state 0x0, keycode 126 (keysym 0xb1, plusminus), same_screen YES,
    XLookupString gives 2 bytes: (c2 b1) "±"
    XmbLookupString gives 2 bytes: (c2 b1) "±"
    XFilterEvent returns: False
KeyRelease event, serial 38, synthetic NO, window 0x4400001, root 0x6a9, subw 0x0, time 10913765, (1291,-68), root:(1342,47), state 0x0, keycode 126 (keysym 0xb1, plusminus), same_screen YES, XLookupString gives 2 bytes: (c2 b1) "±" XFilterEvent returns: False
A B
Using the X event tester xev output:
I take note of the keycode 126 and add the line xmodmap -e "keycode 126 = " (note that I map it to nothing) to the file .bashrc (hidden in the home directory). This has solved my problem, though it is more of a workaround than an actual solution.
A B
