I recently upgraded from version 18 LTS to 20 using Software update, and am noticing random freezing or crashing of the system ever since.
Symptoms The crash usually starts with some windows freezing completely (no responses) (vs code or firefox), and in a short period (30s-60s) the whole system freezes and the only way to proceed is a reboot via power button. Lately, i also noticed some instant crashes, with the whole screen going black. I also noticed crashing usually occurs when using firefox or vs code (but not when intentionally executing hard calculations).
/var/crash
The lastest file is 3 days old, the last crash was today.
urh@urh-laptop:/var/crash$ ls
linux-image-5.4.0-54-generic.203356.crash _opt_teamviewer_tv_bin_teamviewerd.0.uploaded _usr_share_code_code.1000.crash
linux-image-5.4.0-54-generic.213157.crash _usr_bin_gnome-shell.1000.crash _usr_share_code_code.1000.upload
_opt_teamviewer_tv_bin_teamviewerd.0.crash _usr_bin_gnome-shell.1000.upload _usr_share_code_code.1000.uploaded
_opt_teamviewer_tv_bin_teamviewerd.0.upload _usr_bin_gnome-shell.1000.uploaded
Parts from _usr_share_code.1000.crash:
GNU nano 4.8 _usr_share_code_code.1000.crash
ProblemType: Crash
Architecture: amd64
Date: Tue Dec 1 14:01:31 2020
DistroRelease: Ubuntu 20.04
ExecutablePath: /usr/share/code/code
ExecutableTimestamp: 1603764692
ProcCmdline: /usr/share/code/code\ --type=renderer\ --disable-color-correct-rendering\ --no-sandbox\ --field-trial-handle=11739126107242220802,6576820938724679016,131072\ --enable-features=WebComponents>
ProcCwd: /home/urh
ProcEnviron:
ProcMaps:
ProcStatus:
Umask: 0002
State: S (sleeping)
Tgid: 288605
Ngid: 0
Pid: 288605
PPid: 288509
TracerPid: 0
Uid: 1000 1000 1000 1000
Gid: 1000 1000 1000 1000
FDSize: 128
Groups: 4 24 27 30 46 116 126 127 1000
NStgid: 288605
NSpid: 288605
NSpgid: 153351
NSsid: 153351
VmPeak: 8625096 kB
VmSize: 4626800 kB
VmLck: 0 kB
VmPin: 0 kB
VmHWM: 194540 kB
VmRSS: 125928 kB
RssAnon: 38616 kB
RssFile: 87292 kB
RssShmem: 20 kB
VmData: 267896 kB
VmStk: 132 kB
VmExe: 112352 kB
VmLib: 0 kB
VmPTE: 844 kB
VmSwap: 0 kB
HugetlbPages: 0 kB
CoreDumping: 1
THP_enabled: 1
Threads: 20
SigQ: 0/47179
SigPnd: 0000000000000000
ShdPnd: 0000000000000000
SigBlk: 0000000000000000
SigIgn: 0000000000000002
SigCgt: 00000001800010f8
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: 0000003fffffffff
CapAmb: 0000000000000000
NoNewPrivs: 0
Seccomp: 0
Speculation_Store_Bypass: thread vulnerable
Cpus_allowed: f
Cpus_allowed_list: 0-3
Mems_allowed: 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,000000>
Mems_allowed_list: 0
voluntary_ctxt_switches: 11320
nonvoluntary_ctxt_switches: 4009
Signal: 11
Uname: Linux 5.4.0-54-generic x86_64
UserGroups: adm cdrom dip kvm lpadmin plugdev sambashare sudo
INFO
I am running (dualboot) Ubuntu 20.04.1 LTS on Acer Spin 3 with 12gb ram, Intel® Core™ i7-7500U CPU @ 2.70GHz × 4, and Mesa Intel® HD Graphics 620 (KBL GT2).
Gnome version: 3.36.3
Running journalctl -b -1 -e reveals:
dec 05 14:16:12 urh-laptop mtp-probe[466455]: bus: 1, device: 11 was not an MTP device
dec 05 14:16:14 urh-laptop systemd[1]: run-snapd-ns-snap\x2dstore.mnt.mount: Succeeded.
dec 05 14:16:14 urh-laptop systemd[1]: Unmounted /run/snapd/ns/snap-store.mnt.
dec 05 14:16:14 urh-laptop systemd[1]: Unmounting /run/snapd/ns...
dec 05 14:16:14 urh-laptop systemd[1]: run-snapd-ns.mount: Succeeded.
dec 05 14:16:14 urh-laptop systemd[1]: Unmounted /run/snapd/ns.
dec 05 14:16:14 urh-laptop systemd[1]: Stopped target Local File Systems (Pre).
dec 05 14:16:14 urh-laptop systemd[1]: Stopped target Swap.
dec 05 14:16:14 urh-laptop systemd[1]: Deactivating swap /dev/disk/by-id/ata-ST1000LM035-1RK172_WES1A7S2-part3...
dec 05 14:16:14 urh-laptop systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
dec 05 14:16:14 urh-laptop systemd[1]: Stopped Create Static Device Nodes in /dev.
dec 05 14:16:14 urh-laptop systemd[1]: systemd-sysusers.service: Succeeded.
dec 05 14:16:14 urh-laptop systemd[1]: Stopped Create System Users.
dec 05 14:16:14 urh-laptop systemd[1]: systemd-remount-fs.service: Succeeded.
dec 05 14:16:14 urh-laptop systemd[1]: Stopped Remount Root and Kernel File Systems.
dec 05 14:16:14 urh-laptop systemd[1]: Reached target Shutdown.
dec 05 14:16:15 urh-laptop systemd[1]: dev-disk-by\x2dpath-pci\x2d0000:00:17.0\x2data\x2d1\x2dpart3.swap: Succeeded.
dec 05 14:16:15 urh-laptop systemd[1]: Deactivated swap /dev/disk/by-path/pci-0000:00:17.0-ata-1-part3.
dec 05 14:16:15 urh-laptop systemd[1]: dev-disk-by\x2did-ata\x2dST1000LM035\x2d1RK172_WES1A7S2\x2dpart3.swap: Succeeded.
dec 05 14:16:15 urh-laptop systemd[1]: Deactivated swap /dev/disk/by-id/ata-ST1000LM035-1RK172_WES1A7S2-part3.
dec 05 14:16:15 urh-laptop systemd[1]: dev-disk-by\x2did-wwn\x2d0x5000c5009d10879a\x2dpart3.swap: Succeeded.
dec 05 14:16:15 urh-laptop systemd[1]: Deactivated swap /dev/disk/by-id/wwn-0x5000c5009d10879a-part3.
dec 05 14:16:15 urh-laptop systemd[1]: dev-disk-by\x2dpartuuid-00af4d5c\x2d43e1\x2d4918\x2d8b9e\x2d8f331d86bab4.swap: Succeeded.
dec 05 14:16:15 urh-laptop systemd[1]: Deactivated swap /dev/disk/by-partuuid/00af4d5c-43e1-4918-8b9e-8f331d86bab4.
dec 05 14:16:15 urh-laptop systemd[1]: dev-sda3.swap: Succeeded.
dec 05 14:16:15 urh-laptop systemd[1]: Deactivated swap /dev/sda3.
dec 05 14:16:15 urh-laptop systemd[1]: dev-disk-by\x2duuid-86c68832\x2d3661\x2d488d\x2db520\x2dbb94356b7b1f.swap: Succeeded.
dec 05 14:16:15 urh-laptop systemd[1]: Deactivated swap /dev/disk/by-uuid/86c68832-3661-488d-b520-bb94356b7b1f.
dec 05 14:16:15 urh-laptop systemd[1]: Reached target Unmount All Filesystems.
dec 05 14:16:15 urh-laptop systemd[1]: Reached target Final Step.
dec 05 14:16:15 urh-laptop systemd[1]: systemd-poweroff.service: Succeeded.
dec 05 14:16:15 urh-laptop systemd[1]: Finished Power-Off.
dec 05 14:16:15 urh-laptop systemd[1]: Reached target Power-Off.
dec 05 14:16:15 urh-laptop systemd[1]: Shutting down.
dec 05 14:16:15 urh-laptop systemd-shutdown[1]: Syncing filesystems and block devices.
dec 05 14:16:16 urh-laptop systemd-shutdown[1]: Sending SIGTERM to remaining processes...
dec 05 14:16:16 urh-laptop systemd-journald[272]: Journal stopped
urh@urh-laptop:/var/crash$ free -h
total used free shared buff/cache available
Mem: 11Gi 1,6Gi 7,2Gi 330Mi 2,8Gi 9,3Gi
Swap: 9,3Gi 0B 9,3Gi
urh@urh-laptop:/var/crash$ sysctl vm.swappiness
vm.swappiness = 60
urh@urh-laptop:/var/crash$ sudo dmidecode -s bios-version
[sudo] password for urh:
V1.04
urh@urh-laptop:/$ grep -i swap /etc/fstab
# swap was on /dev/sdb3 during installation
UUID=86c68832-3661-488d-b520-bb94356b7b1f none swap sw 0 0
urh@urh-laptop:/$ ls -al /usr/share/gnome-shell/extensions
total 20
drwxr-xr-x 5 root root 4096 nov 3 00:39 .
drwxr-xr-x 7 root root 4096 nov 3 01:33 ..
drwxr-xr-x 2 root root 4096 nov 3 00:39 desktop-icons@csoriano
drwxr-xr-x 3 root root 4096 nov 2 22:03 ubuntu-appindicators@ubuntu.com
drwxr-xr-x 3 root root 4096 dec 1 18:17 ubuntu-dock@ubuntu.com
Ubutnu 18 never crashed. I am a noob, so i cant make anything usefull from crash reporst. I can also provide stuff from /var/log/
Update #1
swapon
urh@urh-laptop:~$ swapon --show
NAME TYPE SIZE USED PRIO
/dev/sda3 partition 9,3G 0B -2
urh@urh-laptop:~$ sudo blkid
/dev/sda3: UUID="86c68832-3661-488d-b520-bb94356b7b1f" TYPE="swap" PARTUUID="00af4d5c-43e1-4918-8b9e-8f331d86bab4"
/dev/sda2: UUID="ac6f5269-f799-4b38-a91a-3688bd842038" TYPE="ext4" PARTUUID="8e1ba2b7-fc9d-4fbc-bbb3-a00170fd283c"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/sda1: LABEL="Podatki" UUID="16161663161643E1" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="ce22c83a-64d0-4091-9773-b65d637375e6"
/dev/sda4: UUID="77ea92d2-e175-4648-a977-726e2ebae872" TYPE="ext4" PARTUUID="da5c0b1c-0285-4717-a98d-e280babb0044"
/dev/sdb1: LABEL="System Reserved" UUID="A620DA0620D9DCFD" TYPE="ntfs" PARTUUID="9abd075d-01"
/dev/sdb2: UUID="F4D8E4B1D8E47372" TYPE="ntfs" PARTUUID="9abd075d-02"
/dev/sdb3: UUID="26AED78EAED754C1" TYPE="ntfs" PARTUUID="9abd075d-03"
/dev/loop8: TYPE="squashfs"
/dev/loop9: TYPE="squashfs"
urh@urh-laptop:~$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sdb2 during installation
UUID=ac6f5269-f799-4b38-a91a-3688bd842038 / ext4 errors=remount-ro 0 1
# /home was on /dev/sdb4 during installation
UUID=77ea92d2-e175-4648-a977-726e2ebae872 /home ext4 defaults 0 2
/dev/disk/by-uuid/16161663161643E1 /mnt/Podatki auto nosuid,nodev,nofail,x-gvfs-show,x-gvfs-name=Podatki 0 0
/dev/disk/by-uuid/F4D8E4B1D8E47372 /mnt/dataFromWindows auto nosuid,nodev,nofail,x-gvfs-show,x-gvfs-name=Data%20From%20Windows 0 0
drwxrwsrwt 2 root whoopsie 4096 dec 5 15:18 .
drwxr-xr-x 14 root root 4096 apr 25 2020 ..
-rw-r--r-- 1 kernoops whoopsie 2787 dec 1 15:57 linux-image-5.4.0-54-generic.203356.crash
-rw-r--r-- 1 kernoops whoopsie 2922 nov 29 19:45 linux-image-5.4.0-54-generic.213157.crash
-rw-r----- 1 root whoopsie 1072334 dec 5 15:05 _opt_teamviewer_tv_bin_teamviewerd.0.crash
-rw-r--r-- 1 root whoopsie 0 dec 2 17:13 _opt_teamviewer_tv_bin_teamviewerd.0.upload
-rw------- 1 whoopsie whoopsie 37 dec 2 17:13 _opt_teamviewer_tv_bin_teamviewerd.0.uploaded
-rw-r----- 1 urh whoopsie 63037944 nov 30 19:57 _usr_bin_gnome-shell.1000.crash
-rw-r--r-- 1 urh whoopsie 0 nov 30 19:57 _usr_bin_gnome-shell.1000.upload
-rw------- 1 whoopsie whoopsie 37 nov 30 19:57 _usr_bin_gnome-shell.1000.uploaded
-rw-r----- 1 urh whoopsie 74784629 dec 1 14:01 _usr_share_code_code.1000.crash
-rw-r----- 1 urh whoopsie 74784631 dec 5 15:18 _usr_share_code_code.1000.crash.save
-rw-r--r-- 1 urh whoopsie 0 dec 1 14:01 _usr_share_code_code.1000.upload
-rw------- 1 whoopsie whoopsie 37 dec 1 14:01 _usr_share_code_code.1000.uploaded
Model: Acer Spin 3
Model Number: N16P9
Update #2
Serial number: NXGK9AA0216480116F7200
SNID: 64800446372
Update #3
urh@urh-laptop:~$ ls -al ~/.local/share/gnome-shell/extensions
ls: cannot access '/home/urh/.local/share/gnome-shell/extensions': No such file or directory
urh@urh-laptop:~$ ls -al /usr/share/gnome-shell/extensions
total 20
Update #4 - SOLUTION?
As suggested by @heynnema , I updated the BIOS. (anoyingly Acer only produces updates for windows, so that was fun). I also added intel_idle.max_cstate=1 in /etc/default/grub and the crashing have stopped for now.
The hint for changing grub was in error code bug soft lockup CPU#2 stuck for 23 s, which only showed one time when crashing. (Usually the screen just went black without showing the log).
