Having used Ubuntu 18.04 for a handful of years now, and reading that Python 2 has been removed from Ubuntu 20.04, I was looking forward to using the commands python or pip rather than python3 or pip3. So today I tried Ubuntu 20.04 for the first time, and found:
$ python --version
Command 'python' not found
$ python3 --version
Python 3.8.5
I was surprised and upon looking into things further found the following about the package python-is-python3:
https://packages.ubuntu.com/focal/python-is-python3
https://launchpad.net/ubuntu/focal/+package/python-is-python3
How to make 'python' program command execute Python 3?
The middle of these 3 links is the most descriptive, but none are especially clear about what python-is-python3 is/does and the full scope of ramifications if sudo apt-get install python-is-python3 was to be ran on a Ubuntu 20.04 install.
Here are some questions I have about python-is-python3:
Is
python-is-python3proprietary to Ubuntu/Canonical? If so, do other Linux distributions usepython-is-python3also or do some other distributions have a similar equivalent?I gather if I was to run
python-is-python3from the command prompt then I could use the commandpythoninstead ofpython3. First can somebody confirm this, and second, does the same go forpip, i.e.pipinstead ofpip3?The launchpad.net link above mentions creation of a symlink. Does
python-is-python3really just create a single symlink? It seems odd to introduce a package for such a bare bones purpose. Also, if this package is subsequently uninstalled (i.e. sudo apt --purge remove python-is-python3) does this remove the symlink?Are there any commonly used Python 2 packages out there anymore? I can't think of any offhand.
Has anybody ran
python-is-python3and then later regretted doing so due to a reason that was not realized ahead of time?It seems the benefit of running
python-is-python3would be not having to add the 3 at the end of Python commands, but the disadvantage is that you would then have a non-standard Ubuntu setup, is this a fair summary of thepython-is-python3benefit/drawback?
