similar questions on this site did not have a solution for me. I'm developing a web app with symfony, and tried to start a local server, which resulted in a warning and didn't start anything
che6yp@aspire:~/Projects/hometowns_api$ symfony server:start
WARNING Web Server log file cannot be tailed: unable to watch log file: no space left on device
I have done this a lot before and never had this problem until recently. One time I closed my Chrome and it helped, but it doesn't help anymore. It seems to me like there is a lot of space left!
df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            3,8G     0  3,8G   0% /dev
tmpfs           781M  2,2M  779M   1% /run
/dev/sda5        92G   36G   52G  41% /
tmpfs           3,9G  414M  3,5G  11% /dev/shm
tmpfs           5,0M  4,0K  5,0M   1% /run/lock
tmpfs           3,9G     0  3,9G   0% /sys/fs/cgroup
/dev/loop0       75M   75M     0 100% /snap/beekeeper-studio/64
/dev/loop3      1,0M  1,0M     0 100% /snap/gnome-logs/100
/dev/loop1      180M  180M     0 100% /snap/telegram-desktop/2185
/dev/loop5      143M  143M     0 100% /snap/slack/33
/dev/loop4      1,0M  1,0M     0 100% /snap/gnome-logs/61
/dev/loop2      218M  218M     0 100% /snap/gnome-3-34-1804/60
/dev/loop7      176M  176M     0 100% /snap/postman/129
/dev/loop6       61M   61M     0 100% /snap/core20/634
/dev/loop9       15M   15M     0 100% /snap/gnome-characters/296
/dev/loop8      143M  143M     0 100% /snap/code/49
/dev/loop12     2,3M  2,3M     0 100% /snap/gnome-system-monitor/148
/dev/loop11     163M  163M     0 100% /snap/gnome-3-28-1804/145
/dev/loop10      65M   65M     0 100% /snap/gtk-common-themes/1513
/dev/loop13     179M  179M     0 100% /snap/telegram-desktop/2198
/dev/loop14      98M   98M     0 100% /snap/core/10126
/dev/loop15      56M   56M     0 100% /snap/core18/1932
/dev/loop16     4,2M  4,2M     0 100% /snap/gnome-calculator/406
/dev/loop18     147M  147M     0 100% /snap/code/50
/dev/loop17     162M  162M     0 100% /snap/gnome-3-28-1804/128
/dev/loop20     149M  149M     0 100% /snap/figma-linux/86
/dev/loop19      98M   98M     0 100% /snap/core/10185
/dev/loop21      75M   75M     0 100% /snap/beekeeper-studio/62
/dev/loop23     2,5M  2,5M     0 100% /snap/gnome-calculator/826
/dev/loop26     3,8M  3,8M     0 100% /snap/gnome-system-monitor/100
/dev/loop25     384K  384K     0 100% /snap/gnome-characters/570
/dev/loop22     174M  174M     0 100% /snap/postman/128
/dev/loop29     144M  144M     0 100% /snap/slack/32
/dev/loop27      63M   63M     0 100% /snap/gtk-common-themes/1506
/dev/loop24      56M   56M     0 100% /snap/core18/1885
/dev/loop28      68M   68M     0 100% /snap/sublime-text/85
/dev/sda2        96M   12M   85M  12% /boot/efi
tmpfs           781M   16K  781M   1% /run/user/121
tmpfs           781M   64K  781M   1% /run/user/1000
df -i
Filesystem      Inodes  IUsed   IFree IUse% Mounted on
udev            992678    614  992064    1% /dev
tmpfs           998718   1224  997494    1% /run
/dev/sda5      6119424 688310 5431114   12% /
tmpfs           998718   1206  997512    1% /dev/shm
tmpfs           998718      6  998712    1% /run/lock
tmpfs           998718     18  998700    1% /sys/fs/cgroup
/dev/loop0         133    133       0  100% /snap/beekeeper-studio/64
/dev/loop3         355    355       0  100% /snap/gnome-logs/100
/dev/loop1       26212  26212       0  100% /snap/telegram-desktop/2185
/dev/loop5       23530  23530       0  100% /snap/slack/33
/dev/loop4         354    354       0  100% /snap/gnome-logs/61
/dev/loop2       18513  18513       0  100% /snap/gnome-3-34-1804/60
/dev/loop7       44282  44282       0  100% /snap/postman/129
/dev/loop6       11573  11573       0  100% /snap/core20/634
/dev/loop9         271    271       0  100% /snap/gnome-characters/296
/dev/loop8        4197   4197       0  100% /snap/code/49
/dev/loop12        784    784       0  100% /snap/gnome-system-monitor/148
/dev/loop11      27807  27807       0  100% /snap/gnome-3-28-1804/145
/dev/loop10      63811  63811       0  100% /snap/gtk-common-themes/1513
/dev/loop13      26205  26205       0  100% /snap/telegram-desktop/2198
/dev/loop14      12815  12815       0  100% /snap/core/10126
/dev/loop15      10779  10779       0  100% /snap/core18/1932
/dev/loop16       1550   1550       0  100% /snap/gnome-calculator/406
/dev/loop18       4197   4197       0  100% /snap/code/50
/dev/loop17      27798  27798       0  100% /snap/gnome-3-28-1804/128
/dev/loop20        705    705       0  100% /snap/figma-linux/86
/dev/loop19      12826  12826       0  100% /snap/core/10185
/dev/loop21        133    133       0  100% /snap/beekeeper-studio/62
/dev/loop23       1384   1384       0  100% /snap/gnome-calculator/826
/dev/loop26        734    734       0  100% /snap/gnome-system-monitor/100
/dev/loop25        230    230       0  100% /snap/gnome-characters/570
/dev/loop22      45118  45118       0  100% /snap/postman/128
/dev/loop29      23537  23537       0  100% /snap/slack/32
/dev/loop27      62342  62342       0  100% /snap/gtk-common-themes/1506
/dev/loop24      10775  10775       0  100% /snap/core18/1885
/dev/loop28      14689  14689       0  100% /snap/sublime-text/85
/dev/sda2            0      0       0     - /boot/efi
tmpfs           998718     25  998693    1% /run/user/121
tmpfs           998718     46  998672    1% /run/user/1000
sudo du -h --max-depth=1 /
12M /sbin
0   /sys
13M /bin
4,0K    /mnt
949M    /lib
4,0K    /.cache
du: cannot access '/run/user/1000/doc': Permission denied
du: cannot access '/run/user/1000/gvfs': Permission denied
2,2M    /run
16K /dev
6,4G    /var
128K    /tmp
226M    /opt
11G /snap
126M    /boot
4,0K    /lib64
40K /root
16K /lost+found
4,9G    /usr
15M /etc
4,0K    /media
4,0K    /cdrom
du: cannot access '/proc/28237': No such file or directory
du: cannot access '/proc/28270/task/28270/fd/4': No such file or directory
du: cannot access '/proc/28270/task/28270/fdinfo/4': No such file or directory
du: cannot access '/proc/28270/fd/3': No such file or directory
du: cannot access '/proc/28270/fdinfo/3': No such file or directory
0   /proc
21G /home
4,0K    /srv
46G /
free -m
              total        used        free      shared  buff/cache   available
Mem:           7802        3912         484         472        3405        3117
Swap:          2047         152        1895
ps -a
  PID TTY          TIME CMD
 2278 tty1     00:00:00 gnome-session-b
 2415 tty1     00:00:30 gnome-shell
 2689 tty1     00:00:00 Xwayland
 4164 tty1     00:00:00 ibus-daemon
 4169 tty1     00:00:00 ibus-dconf
 4171 tty1     00:00:00 ibus-x11
 4257 tty1     00:00:00 gsd-xsettings
 4260 tty1     00:00:00 gsd-a11y-settin
 4261 tty1     00:00:00 gsd-clipboard
 4264 tty1     00:00:01 gsd-color
 4265 tty1     00:00:00 gsd-datetime
 4266 tty1     00:00:00 gsd-housekeepin
 4267 tty1     00:00:00 gsd-keyboard
 4268 tty1     00:00:00 gsd-media-keys
 4273 tty1     00:00:00 gsd-mouse
 4276 tty1     00:00:00 gsd-power
 4279 tty1     00:00:00 gsd-print-notif
 4280 tty1     00:00:00 gsd-rfkill
 4281 tty1     00:00:00 gsd-screensaver
 4286 tty1     00:00:00 gsd-sharing
 4290 tty1     00:00:00 gsd-smartcard
 4294 tty1     00:00:00 gsd-sound
 4297 tty1     00:00:00 gsd-wacom
 4307 tty1     00:00:00 ibus-engine-sim
 6614 tty2     00:17:14 Xorg
 6668 tty2     00:00:01 gnome-session-b
 6789 tty2     00:18:58 gnome-shell
 6833 tty2     00:00:35 ibus-daemon
 6843 tty2     00:00:00 ibus-dconf
 6845 tty2     00:00:00 ibus-x11
 6920 tty2     00:00:00 gsd-power
 6922 tty2     00:00:00 gsd-print-notif
 6923 tty2     00:00:00 gsd-rfkill
 6926 tty2     00:00:00 gsd-screensaver
 6927 tty2     00:00:01 gsd-sharing
 6930 tty2     00:00:00 gsd-smartcard
 6940 tty2     00:00:00 gsd-xsettings
 6951 tty2     00:00:00 gsd-sound
 6952 tty2     00:00:00 gsd-wacom
 6958 tty2     00:00:00 gsd-clipboard
 6959 tty2     00:00:00 gsd-a11y-settin
 6961 tty2     00:00:00 gsd-datetime
 6963 tty2     00:00:02 gsd-color
 6966 tty2     00:00:00 gsd-keyboard
 6967 tty2     00:00:01 gsd-housekeepin
 6968 tty2     00:00:00 gsd-mouse
 6972 tty2     00:00:01 gsd-media-keys
 7062 tty2     00:00:03 nautilus-deskto
 7065 tty2     00:00:00 gsd-printer
 7078 tty2     00:00:00 gsd-disk-utilit
 7100 tty2     00:00:11 ibus-engine-sim
 7191 tty2     00:41:54 telegram-deskto
 7374 tty2     00:00:04 gnome-software
 7377 tty2     00:00:00 update-notifier
 7503 tty2     00:00:00 deja-dup-monito
 7542 tty2     00:17:37 chrome
 7548 tty2     00:00:00 cat
 7549 tty2     00:00:00 cat
 7553 tty2     00:00:00 chrome
 7555 tty2     00:00:00 chrome
 7560 tty2     00:00:00 nacl_helper
 7561 tty2     00:00:00 nacl_helper
 7564 tty2     00:00:00 chrome
 7584 tty2     00:23:50 chrome
 7589 tty2     00:03:35 chrome
 7600 tty2     00:00:00 chrome
 7601 tty2     00:00:13 chrome
 7630 tty2     00:00:13 chrome
 7690 tty2     00:02:27 chrome
 7704 tty2     00:02:12 chrome
 7715 tty2     00:00:37 chrome
 7721 tty2     00:00:40 chrome
 7727 tty2     00:01:10 chrome
 7733 tty2     00:01:27 chrome
 8019 tty2     00:07:48 chrome
 8079 tty2     00:02:24 chrome
 8849 tty2     00:00:41 chrome
 8880 tty2     00:00:22 chrome
15904 tty2     00:00:05 chrome
24202 tty2     00:01:57 chrome
27125 tty2     00:00:12 chrome
27650 tty2     00:02:02 chrome
27669 tty2     00:00:02 chrome
27718 tty2     00:00:02 chrome
27756 tty2     00:00:02 chrome
27876 tty2     00:00:01 chrome
28119 tty2     00:00:00 chrome
28302 pts/0    00:00:00 ps
Thank you!
CHE6yp
