I have been researching this problem for a while now, so I hope this isn't a duplicate.
I am running two SSDs on my system. One for Windows 10, one for Linux. After installing Ubuntu 20.04 on the Linux SSD (replacing the previous debian installation), the device is no longer listed as an UEFI device in the EFI setup utility. I am not able to set this device as the primary boot option. However, when I use the boot menu (F11). The drive is listed. I can select it and Grub starts correctly. I can also run Win from there.
I did the following:
- Create a bootable USB drive (according to this: How to create UEFI-only bootable USB live media?)
- Booted the drive in UEFI mode
- Use custom partitioning. Create a 300MB partition with mount point
/boot/efiand flagboot
Things I have tried:
- Add the
ESPflag after installing using gparted - Reinstall having
secure bootturned off - Reinstall using
UEFI + Legacymode - I was checking out the
boot-repairtool. This lists that the EFI partition is present - The output of
efibootmgr -vis as follows:
root@lubuntu:/home/lubuntu# efibootmgr -v
BootCurrent: 0005
Timeout: 1 seconds
BootOrder: 0001,0000,0003,0005,0004
Boot0000* Windows Boot Manager HD(2,GPT,45163052-5fdf-4174-a84b-9383a3e67e8b,0x109000,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...M................
Boot0001* Hard Drive BBS(HD,,0x0)/VenHw(5ce8128b-2cec-40f0-8372-80640e3dc858,0200)..GO..NO..........S.a.m.s.u.n.g. .S.S.D. .8.5.0. .E.V.O. .2.5.0.G.B...................\.,.@.r.d.=.X..........A.................................>..Gd-.;.A..MQ..L.2.S.6.R.X.N.J.0.0.7.9.5.9.7. .A. . . . ........BO..NO..........S.a.m.s.u.n.g. .S.S.D. .8.5.0. .E.V.O. .2.5.0.G.B...................\.,.@.r.d.=.X..........A.................................>..Gd-.;.A..MQ..L.2.S.6.R.X.N.J.1.1.1.6.7.8.4. .N. . . . ........BO..NO..........S.T.2.0.0.0.D.M.0.0.8.-.2.F.R.1.0.2...................\.,.@.r.d.=.X..........A.................................>..Gd-.;.A..MQ..L. . . . . . . . . . . . .F.Z.1.L.7.L.L.Y........BO..NO..........S.T.2.0.0.0.D.M.0.0.6.-.2.D.M.1.6.4...................\.,.@.r.d.=.X..........A.................................>..Gd-.;.A..MQ..L. . . . . . . . . . . . .4.Z.7.Z.V.W.G.D........BO
Boot0003* ubuntu HD(1,GPT,971a9558-bfc4-644a-8ad3-274e7f78c4ae,0x800,0x96000)/File(\EFI\UBUNTU\SHIMX64.EFI)
Boot0004* USB KEY BBS(HD,,0x0)/VenHw(5ce8128b-2cec-40f0-8372-80640e3dc858,0b00)..GO..NO..........S.a.n.D.i.s.k...................\.,.@.r.d.=.X..........A.............................>..Gd-.;.A..MQ..L.4.C.5.3.0.0.0.0.2.0.0.1.2.3.1.1.8.2.9.5........BO
Boot0005* UEFI: SanDisk, Partition 1 PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(2,0)/HD(1,MBR,0x0,0x800,0x3947800)..BO
I am really quite stumped by this. Advice is greatly appreciated.
The mainboard I am using is a MSI B350 PC Mate
