I'm new in the Linux world. So I've installed Ubuntu 20.4 on my Macbook Air 2014... Everything works fine, audio, microphone, however, my problem arises when I try to plug in the headphone. The audio works fine, but I can't seen to make the headset mic to work.
I did some research, found this topic
Did all the workarounds... I've looked up on the kernel website to see which codec my computer uses:
Cirrus Logic CS4208 mba6 MacBook Air 6,1 and 6,2
Then I've openned Visual Studio and added the line bellow at the bottom of /etc/modprobe.d/alsa-base.conf
options snd-hda-intel model=mba6
After reboot, nothing has changed. Does anyone know how to fix this problem?
digolira2
  • 153
Ok folks I managed to solve the issue:
First check without unplugging the cable the result of:
sudo hdajacksensetest -a
Then connect the cable and run it again:
There should be some difference, with now some pin marked as "(Not connected): present = Yes" which initially (without the cable) showed "(Not connected): present = No". If this is not the case your cable is not being detected and you may have another issue.
Then run:
cat /proc/asound/card*/codec* | grep Codec
And make sure it is Cirrus Logic CS4208 , if that is the case, search the particular model of your computer here: https://www.kernel.org/doc/html/latest/sound/hd-audio/models.html (in the CS4208 section if that is your case) find the code of your computer: mbp55 or imac27 or imac27_122 and then edit /etc/modprobe.d/alsa-base.conf. Erase every line in there and write (supposing your model was mbp55):
options snd-hda-intel model=mbp55
Then restart the computer and it should work (Solution by Doug White)
