22
Yesterday I upgraded my Ubuntu by SSH but before I finished it, I restarted my computer. I know that was not very smart. Anyway now I don't have internet connection, the WiFi or Ethernet is not recognized.
When I try on the latest version installed, the mice didn't work. When I try with previous version and go in gnome-network manager it's said:
The system network service is not compatible with this version
Another thing is when I comeback to the remote computer and look at the SSH terminal the process have stopped at:
Setting up desktop-file-utils (0.20-0ubuntu2) ...
Configuration file `/etc/gnome/defaults.list'
==> Modified (by you or by a script)
since installation. ==> Package distributor has shipped
an updated version. What would you like to do about it ?
Your options are: Y or I:install the package maintainer's
version N or O : keep your currently-installed version D :
show the differences between the versions Z : start a shell
to examine the situation The default action is to keep your
current version. * defaults.list (Y/I/N/O/D/Z) [default=N] ?
Write failed: Broken pipe
Is there any simple solution other than I having to reinstall my system?
jokerdino
  • 41,732
ucsky
  • 471
8 Answers8
19
I faced the same issue. Workaround is to start the network-manager manually
sudo service network-manager start
Still trying to figure a way to fix it permanently.
devav2
  • 37,290
15
Edit: This answer is over six years old and is no longer fresh due to changes in Ubuntu. This is a workaround.
Go into settings, startup items. Add an entry with the following command:
In a terminal, use visudo to add a NOPASSWD entry for this command so you do not need to give a password:
your-username-here ALL=NOPASSWD: service network-manager start
Next time you log on, this will force a start of the network manager (supposing that it is configured such that it can start up).
nanofarad
  • 20,906
I had to reinstall the NetworkManager package and reboot. Everything was fine then.
sudo apt-get --reinstall install network-manager
Just stick the following in /etc/rc.local before the line that says "exit":
NetworkManager
That should launch it whenever your system starts. A better way would be to add it to the appropriate init scripts so that it doesn't start in single user mode, but honestly it won't hurt anything this way either.
Chris
  • 31
I also had a partially-complete upgrade cause this issue, but my fix was different. Turns out that network-manager won't start at boot if any of the interfaces in /etc/network/interfaces marked auto don't come online. Basically, the static network configuration stuff should all come online before network-manager will be triggered. For me, this was a stray eth0 configured to use dhcp. I had unplugged the ethernet from my box, and suddenly this problem emerged. Solution was to remove everything but the loopback interface from /etc/network/interfaces. See this link for more info
Hamy
  • 500
My install completed successfully, but I got the same error. Turns out that a new update (which reintroduces an old bug) causes network manager to crash. See here for the fix: Last upgrade crashes network manager (no internet connection, no applet)
guttermonk
  • 1,024
If the installation was interrupted, you might get good results by fixing it with
sudo apt-get install -f
I just had what I think was the same problem OP had, starting manually the Network Manager provided me with the icon in unity, but no interfaces visible, while the above mentioned command and a reboot fixed the issue completely.
While check network configuration found some additional ethernet, I have just removed it and it works for me!
ls /etc/sysconfig/network-scripts
ifcfg-Auto_Ethernet
ifcfg-Auto_Ethernet-1 ifcfg-Auto_Ethernet-2 ifcfg-Auto_Ethernet-3 ifcfg-Auto_Ethernet-4 ifcfg-Auto_Ethernet-5
rm -rf ifcfg-Auto_Ethernet*
[root@ac2 network-scripts]# service network restart Restarting network (via systemctl): [ OK ]
user68186
  • 37,461
