I'm trying to take advantage of the starring option in Nautilus. But it seems like there is a Bug which doesn't allow to "star" no indexed directories.
How do I add a directory to the index?
screenshot "stared" directories
Note 1: right now it seems like I can only star directories in the first level of the Users folder as well as in the default folders like Desktop, Documents, Downloads etc.
Note 2: the way starring how it worked in Ubuntu 19.04 seems not work anymore.
wittich
  • 1,214
Nautilus uses Tracker to index the files in the system. We can use tracker command to add new files or directory.
tracker index --help
NAME tracker-index - List, pause, resume and command data miners indexing content
SYNOPSIS tracker index --reindex-mime-type <mime1> [[-m [mime2]] ...] tracker index --file <file1> [[file2] ...] tracker index --import <file1> [[file2] ...] tracker index --backup <file> | --restore <file>
Check current indexed folders and files:
tracker status
Currently indexed: 373 files, 49 folders Remaining space on database partition: 234.0 GB (55.50%) All data miners are idle, indexing complete
For instance if you want to index this additional folder /home/user/newfolder
tracker index --file /home/user/newfolder
Confirm that the new folder has been indexed.
Should output more files and folders than before.
tracker status
In Ubuntu 20.10, the command to add a directory, and its sub-directories, is...
$ tracker3 index --add --recursive Dir
...where Dir is the path to your directory.
To list the directories being indexed, use...
$ tracker3 index
More information... $ info tracker3-index
Mike
