Suppose I want to use some GUI programs that were provided in an old release of Ubuntu. I am currently using a later version of Ubuntu that does not provide these GUI programs. Is there a reliable way install these old programs without messing up my existing packages, and without having to use virtualization (e.g. VirtualBox)?
I have read this question: How do I install Qtstalker on Ubuntu 17.10?, which is about installing Qtstalker, a program that was available in Ubuntu 12.04 Precise Pangolin, but which has been removed from later Ubuntu releases because the upstream has ceased development. The answer there uses chroot. I am wondering: is the method generally applicable to other programs too? Is chroot the proper and usual solution to the problem?
Suppose I want to play XBattle, which was available in Ubuntu 12.04 Precise Pangolin, but was subsequently removed. Should I use chroot to play it in Ubuntu 18.04 Bionic Beaver?
I read https://packaging.ubuntu.com/html/chroots.html, but the page seems to imply that chroot is a packaging tool rather than something that one would use for running programs regularly.
Other answers suggesting a chroot solution to such problems: The packages for old releases are not available anymore?
