seeing my system logs, they are full of msgs like this:
/usr/libexec/gdm-x-session[2564]: (EE) event4  - SIGMACHIP USB Keyboard: client bug: event processing lagging behind by 25ms, your system is too slow
/usr/libexec/gdm-x-session[2564]: (EE) event4  - SIGMACHIP USB Keyboard: client bug: event processing lagging behind by 17ms, your system is too slow
i have a 12 core system which is essentially idle when i see this. it seems to happen since i upgraded to Ubuntu 20.10.
how can i find the root cause and how to eliminate this issue?
sys info:
model name  : AMD Ryzen 9 3900X 12-Core Processor
/sys/devices/system/cpu/cpufreq/policy10/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpufreq/policy0/scaling_governor:ondemand
grep . /sys/devices/system/cpu/cpuidle/*
/sys/devices/system/cpu/cpuidle/available_governors:ladder menu teo
/sys/devices/system/cpu/cpuidle/current_driver:acpi_idle
/sys/devices/system/cpu/cpuidle/current_governor:menu
/sys/devices/system/cpu/cpuidle/current_governor_ro:menu
pdeva
  • 149
That error message is not from the kernel, and is somewhat misleading. It isn't even really an error, more a warning. Some think that it should say:
your compositor is too slow
instead of
Ignore it.
References:
https://forums.gentoo.org/viewtopic-t-1117556-start-0.html
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=968093
Doug Smythies
  • 16,146
This is something I've seen on machines that have an Nvidia graphics card installed. In my case, the driver was out of date and an update resolved the issue (as well as a frame-dropping issue that had developed after upgrading from 19.10 to 20.04). My CPU is a lot slower than your Ryzen, but this could be an area to examine.
I had the same issue here.
CPU: model name : AMD Ryzen 9 5950X 16-Core Processor
An update form nvidia driver 390X to 460.73.01 was the first step. Thx to @user1091774
The bluetooth connection was still laggy so i switch to the Unified dongle.
Maybe this has some effect too:
cat /etc/udev/rules.d/50-usb_power_save.rules
ACTION=="add", SUBSYSTEM=="usb", TEST=="power/control", ATTR{power/control}="on"
The errors in log are gone.
