I can mute and unmute the microphone just fine, but the white light on the mic mute button (F4) is on at all times. How can I make it respond to the muted/unmuted state of the microphone, or even just turn it off completely? It's very bright.
Asked
Active
Viewed 3,564 times
I am using ThinkPad P14s AMD, following works if you want to manually change it.
You can test to see if it works for you:
echo 1 | sudo tee /sys/class/leds/platform\:\:micmute/brightness
to turn it on, and
echo 0 | sudo tee /sys/class/leds/platform\:\:micmute/brightness
to turn it off.
Aditya T
- 154
