How to send mail from the command line?
Install ssmtp
:sudo apt-get install ssmtpEdit the ssmtp config file:
gksu gedit /etc/ssmtp/ssmtp.confAppend the following text:
root=username@gmail.com mailhub=smtp.gmail.com:465 rewriteDomain=gmail.com AuthUser=username AuthPass=password FromLineOverride=YES UseTLS=YESRun ssmtp and provide the recipient email address:
ssmtp recepient_name@gmail.comProvide the message details as follows:
To: recipient_name@gmail.com From: username@gmail.com Subject: Sent from a terminal! Your content goes here. Lorem ipsum dolor sit amet, consectetur adipisicing. (Notice the blank space between the subject and the body.)Press Ctrl + D to send.
You can also put the text in file and send it as follows:
ssmtp recipient_name@gmail.com < filename.txt
Most of the time you shouldn't need to configure an SMTP server you can simply use mail from the commandline (if it's not already present, install with sudo apt-get install mailutils). (Or if you're on a server where sendmail is configured, etc)
marco@dagobah:~$ mail -v marco.ceppi.use@gmail.com
Subject: Hello World!
This is an email to myself.
Hope all is well.
Cc:
You terminate messages with a single . on line. That's when mail will prompt you for Cc: enter the information (or leave blank) and mail will then print out additional information on what it is attempting to do, as well as detailing the processing of connecting, transmitting, and receiving data from the mail server.
- 747
- 48,827
apt-get install sendemail
usage:
sendemail -f fromuser@gmail.com -t touser@domain.com -u subject -m "message" -s smtp.gmail.com:587 -o tls=yes -xu gmailaccount@gmail.com -xp gmailpassword
If you don't want to specify your password in the command line (generally not a good thing to do), you can omit that parameter and sendemail will prompt you for the password... and display it on the screen, but at least it won't be in your command line history.
Try to install The Mutt E-mail Client. Other option is using emacs with gnus. Others options available too... IMHO, you should use more details in your questions, or several different answers to your question you will receive :-)
- 2,869
mpack is excellent commandline way of sending file attachments.
apt-get install mpack
usage:
mpack -s "file you wanted" ./data.pdf loser@supergoober.cn
- 331
Install the package sendmail then type
sendmail -t receiver@example
then write your email then press Ctrl+D
- 311
mail -s "subjet" -a "attchedfile_name" someone@dest_email.com
or
cat "afile" | mail -s "subject" someone@dest_email.com
- 55,453
- 111
You can send an email from the command line with TelNet or NetCat.
Everything is explained here.
hanoo@hp_laptop% nc 127.0.0.1 25
220 hp_laptop.localdomain ESMTP Postfix
EHLO man
250 hp_laptop.localdomain
MAIL FROM: <netcat@postfix.com>
250 2.1.0 Ok
RCPT TO: <target@host.com>
250 2.1.5 Ok
data
354 End data with <CR><LF>.<CR><LF>
This is the body of my mail,
this is the second line...
250 2.0.0 Ok: queued as 9C12E7F404
If you try to send e-mail from a system, whitch does not run an own e-mail-server (i. e. desktop system), you need to install something like nullmailer or esmtp, which forward your local mail to a "real" mail server.
As command line tools you can install mail or mailx (packages mailutils, heirloom-mailx or bsd-mailx). If you need attachments try biabam.
- 3,149
You can use cURL. Take a file like this:
To: Monday <monday@gmail.com>
Subject: Tuesday
Wednesday
and send it:
curl \
--netrc \
--mail-rcpt monday@gmail.com \
--upload-file a.txt \
smtps://smtp.gmail.com
- 1
You can try this:
mail name@mailserver.com -s "Attached file" <<EOF
Hi
~| uuencode $HOME/filename.txt filename.txt
EOF
It works with GNU Mailutils, check the website for more information.
Run:
sudo -H gedit /etc/ssmtp/ssmtp.conf
The following needs to be added there:
# The user that gets all the mails (UID < 1000, usually the admin)
root=yourusernameofgmail@gmail.com
# The mail server (where the mail is sent to), both port 465 or 587 should be acceptable
# See also https://support.google.com/mail/answer/78799
mailhub=smtp.gmail.com:587
# The address where the mail appears to come from for user authentication.
# Use SSL/TLS before starting negotiation
UseTLS=Yes
UseSTARTTLS=Yes
# Username/Password
AuthUser=yourusernameofgmail
AuthPass=yourGmailPassowrd
AuthMethod=LOGIN
# Email 'From header's can override the default domain?
FromLineOverride=yes
Run:
sudo -H gedit /etc/ssmtp/revaliases
Enter there:
root:yourusernameofgmail@gmail.com:smtp.gmail.com:587
Enable "less secure apps" on Gmail:
https://support.google.com/accounts/answer/6010255?hl=en
Test it by running the following on terminal:
echo "Body of mail is abc" | mail -s "Subject is xyz" "someusername@gmail.com"`
- 72,312
- 401
- 3
- 8
- 21
I want to add another quite simple yet interesting way to do, provided by AWS (link)
So, you need to prepare this text file, save it as input.txt. Please remember to change the values:
Replace example.com with your sending domain.
Replace Base64EncodedSMTPUserName with your base64-encoded SMTP username.
Replace Base64EncodedSMTPPassword with your base64-encoded SMTP password.
Replace sender@example.com with the email address you are sending from. This identity must be verified.
Replace recipient@example.com with the destination email address. If your Amazon SES account is still in the sandbox, this address must be verified.
EHLO example.com AUTH LOGIN Base64EncodedSMTPUserName Base64EncodedSMTPPassword MAIL FROM: sender@example.com RCPT TO: recipient@example.com DATA From: Sender Name <sender@example.com> To: recipient@example.com Subject: Amazon SES SMTP TestThis message was sent using the Amazon SES SMTP interface. . QUIT
To send using explicit SSL over port 587 – Enter the following command:
openssl s_client -crlf -quiet -starttls smtp -connect smtp-server-endpoint:587 < input.txtTo send using implicit SSL over port 465 – Enter the following command:
openssl s_client -crlf -quiet -connect smtp-server-endpoint:465 < input.txt
Impatient SMTP servers
If you face Client host rejected: Improper use of SMTP command pipelining errors, try waiting for the responses:
openssl s_client -crlf -quiet -starttls smtp -connect smtp.example.com:587 < \
echo "EHLO foo.tld"
sleep 2
echo "AUTH LOGIN"
sleep 2
echo "Base64EncodedSMTPUserName"
sleep 2
echo "Base64EncodedSMTPPassword"
sleep 2
echo "MAIL FROM: sender@example.com"
sleep 2
echo "RCPT TO: recipient@example.com"
sleep 2
echo "DATA"
sleep 2
echo "Sender Name <sender@example.com>"
echo "recipient@example.com"
echo "Subject: Test"
echo ""
echo "Lorem Ipsum"
echo "."
echo "QUIT"
- 150
- 29
- 7
